General Automotive Discussion
Truck Wont Start BUt Battery good
Old 04-27-2013, 10:09 PM
lditges1's Avatar
lditges1
lditges1 is offline
I have a 2000 Ford F250 7.3 when I slam the hood it will power up but as soon as I plug the key in the truck immediately dies. I tested the battery is good. Please Help stuck in midland if I cant figure this problem out.
Old 04-27-2013, 10:49 PM
Furyus1's Avatar
Furyus1
Furyus1 is offline
Welcome to FTE.
How did you test the battery - was it tested under load?
Old 04-28-2013, 12:18 AM
ford2go's Avatar
ford2go
ford2go is offline
Please give a few more details --
Sounds like you 'somehow' get it started when you slam the hood -- are you using your remote?
Then when you put the actual key in it dies. Do I have that right?
If it's a key that works with the anti theft, maybe it's not being recognized. I know almost nothing about those systems, but I would assume that a dealer could check to see if the chip in the key is working.
Good Luck,
hj
Old 04-28-2013, 11:55 AM
galaxie641's Avatar
galaxie641
galaxie641 is offline
Pull the connections off, clean and reinstall, also make sure the cables aren't rotting out under the insulation.
david gelbach
2017+ Super Duty
07-01-2018 03:13 AM
wtroger
2011 to 2019 Explorer
09-05-2017 11:37 AM
cmalley12
6.4L Power Stroke Diesel
12-03-2012 08:29 PM
sabresfan616
08-20-2012 06:41 AM
Christinas ex
05-17-2010 10:08 AM
Quick Reply: Truck Wont Start BUt Battery good
