Fuel Pressure Regulator
on
What trans is in your truck? If it's an auto this is a lot more complicated than you may think.. that trans is computer controlled and it needs input from the engine sensors or the trans won't function properly. So if that's the case you may as well put the EFI system on the replacement motor and bolt it in, but if you have a manual trans then you need a bypass fuel regulator and a duraspark distributor and ignition box.
Why the hell do people wanna go back to carburetors. Fords fuel injection system is a damn fine system. Just bolt the EFI intake onto the carb'd 302 and put it in your truck and never look back at the carb and carb intake. As a matter of fact, just sell it the carb and intake.
on
fuel+regulator+302 - JEGS High Performance
rangergirl94
15
03-22-2012 06:20 PM
smfish9
12-08-2010 12:01 PM
fordboy16
Computer Chips & Tuners
10-13-2009 05:53 PM
kkurtdirt
05-05-2007 10:11 AM
