1978 - 1996 Big Bronco
Ford Ignition Module
Old 04-19-2013, 06:53 AM
Fordman96's Avatar
Fordman96
Fordman96 is offline
So a few years ago when I wrecked the Wrongco.. I got a new front clip from what I believe was a 96' F250 or F350 with a 460 and ZF-5 manual trans.
On the fender when I got it was the ignition module.
Ignition module f1sf-12a297-c1a4L05A | Flickr - Photo Sharing!@@AMEPARAM@@http://farm9.staticflickr.com/8255/8661995349_90ac2059db_m.jpg@@AMEPARAM@@8661995349@@AMEPARAM@@90ac2059db
The numbers on it are F1SF-12A297-C1A and below that is 4L05A.
I just want to check, but I'm pretty sure that I already know the answer. The module won't work for 96' 351w correct? I had it on the truck when I first got it running again, but it ran really, really rich.
Old 04-20-2013, 12:21 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,172 Likes on 926 Posts
You have the correct black Ignition Control Module. Many parts manuals are wrong, including Ford. 1994 and up trucks use the black colored CCD-style ICM.
Old 04-20-2013, 07:12 PM
Fordman96's Avatar
Fordman96
So will that work with my 96' 351W and E4OD?
Old 04-21-2013, 07:21 AM
b4hntn's Avatar
b4hntn
b4hntn is offline
ICM
Probably. The black Motorcraft are hard to find. I am running a Taurus 6cyl in my 5.8 and my spare is from a straight six truck 300. Both work great.
The wiring connector and heat sink are the same but the computer controls the dwell and the wiring is different in the later year CCD design.
I bought a couple of Motorcraft grey ones which do not work so let me know if anyone wants them.
Of course pulling codes is the first step for running rich. Thermostat should be 195. Then if codes are good, look at O2, ECT and ACT.
Old 04-21-2013, 07:37 AM
Fordman96's Avatar
Fordman96
My current codes are p0171 bank one running rich. P1506 IAC over speed. P1401 EGR sensor messed up (but I've know about that.
Old 04-21-2013, 05:35 PM
rla2005's Avatar
rla2005
rla2005 is offline
Yes, the black ICM from the other truck will work just fine.
Some great info: Ford TFI Ignition Control Modules - FSB Forums
Some other info you may find handy:
Remote Mount Black CCD "Computer Controlled Dwell" ICM
Ford Bronco - Wiring Schematic
Motorcraft - DY1077 (supercedes DY679, DY667, DY645)
Ford - 5U2Z-12A297-D (supercedes F1PZ-12A297-A)
Wells - F139
Niehoff - FF413
BWD - CBE40
Standard - LX-241
NapaEchlin - TP29
Delphi - DS10056
Transpo - FM544
Old 04-22-2013, 06:38 AM
eatsrottenflesh's Avatar
eatsrottenflesh
eatsrottenflesh is offline
p0171 is bank one lean not rich, isnt it? combined with p1506 idle speed, i would be looking for a vacuum leak on the pass side of the engine.
Old 04-22-2013, 04:19 PM
Fordman96's Avatar
Fordman96
Well I drove the truck today and it idled correctly and seemed to run better then it has been in the last week. I haven't narrowed down a vacuum leak yet but as far as I can tell I don't have one.
abyars111
02-12-2021 09:08 AM
jgrohs54
01-21-2016 10:43 AM
perryau1996
10-03-2011 11:33 AM
jdon88
02-16-2004 07:09 AM
Henryf250
07-26-2003 09:11 AM
Quick Reply: Ford Ignition Module
