Need help with dash removal.
I am trying to remove my dash. My truck is an '86 F-250. I am trying to remove the piece directly above the steering wheel. Not the top of the dash but the "wood grain" piece. I have it loose and free form everything but I cannot slip it off the steering column. I'm afraid of breaking it by pulling to hard. Is there a trick or do I have to remove the steering wheel?
That shroud I described earlier, it might be harder to remove than I first described... yes, there is just the one screw holding it together, but there's a trim panel under there that will maybe get in the way that would need to first be removed (forgot about that).
something I remember doing is moving one "leg" of the bezel forward and the other one back, I think I've gotten 'em off thataway before....
Thanks for the help guys. I already had that lower piece so off so when I looked I saw the screw you mentioned. I removed that and the shroud and it was easy to get the bezel off. I had the bezel all way up to the steering wheel turning it around trying to twist it off , definitely easier to remove the shroud. Gauge cluster is next! I have most of it off just have to unplug it the wires and cable. I found a thread on here discussing that so I'll give it a go tomorrow.
Your wires have a leg on both sides you need to flex out to remove it.
The speedo cable has 1 leg to flex out to remove it.
4 screws hold the bezel in. 5 bulbs light up the cluster. Part# 194. 5 bulbs for the info lights, same part#. If you remove the cluster bulbs (they twist out) may as well poke out the filters inside the bulbholes. Firm push wit a stubby screwdriver or pencil. Really brightens up the cluster.
I got the cluster out! I want remove the rest of it now. I think I have to remove the heater, stereo, and glovebox next. I want to remove everything for a few reasons: 1) my dash is broken where the park brake bracket bolts to it, 2) my clutch pedal will not return when pressed down without the aid of a bungee cord and I want to see what's going on, 3) the insulation/rubber mat against the firewall is wet and gross, I am seeing rust as well. I'll keep you posted on my progress. Slow going because I have the truck stored at the shop I work for. Can only work on it during breaks or if someone is staying late.
Truck Guy99
11-09-2015 11:31 PM
