dash removal
Old Mar 11, 2006 | 06:25 PM
theguy_88's Avatar
theguy_88
Question dash removal
how do u remove the dash from a 77 f-250? do u have to remove the stering column and if u do how do u do that too?
Old Mar 11, 2006 | 08:30 PM
ivanribic's Avatar
ivanribic
There are 2 bolts that hold it to the side walls, one on each side and then 2 over the steering column and a series of screws across the top of the dash. That's all that holds the dash itself in. You'll need to make sure you get the gauge cluster and heater controls disconnected too.
Old Mar 11, 2006 | 09:22 PM
theguy_88's Avatar
theguy_88
do u have to take the steering column out? or what on the steering column do u have to remove?
Old Mar 12, 2006 | 12:24 AM
Indybroncoman's Avatar
Indybroncoman
The steering column does not have to be removed. My dash is out now and the column is still in.
Old Mar 12, 2006 | 12:29 AM
FordPickup460's Avatar
FordPickup460
You have to remove the collar piece thats under the steering coulmn. Theres 2 screws holding it on under the dash, 1 on each side, once you remove those the collar slides down and out.
Old Mar 12, 2006 | 01:02 AM
ivanribic's Avatar
ivanribic
If you remove the gauge cluster you'll see the 2 bolts over the steering column very clearly. But as stated the column itself can stay put.
Old Mar 12, 2006 | 01:38 AM
Indybroncoman
These pics might clear it up some. They are shots taken after I removed the dash and you can see that the steering column is still attached.
http://www.supermotors.org/vehicles/....php?id=290667
http://www.supermotors.org/vehicles/....php?id=290514
You can also see the detached speedometer cable. Good luck! It's not difficult, only a little time-consuming.
