6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
2008 Radiator drain plug. Where is the thing?
Old 04-13-2013, 07:42 AM
ktheavner's Avatar
ktheavner
ktheavner is offline
Trying to install enine coolant filter and instructions say drain 2 gallons of coolant from radiator. This would not be a problem but I cant find the drain for the radiator. I must be blind or stupit. Can someone help the blind? Thanks, KT
Old 04-13-2013, 06:45 PM
UGA33's Avatar
UGA33
UGA33 is offline
Drivers side of the radiator. Lay under truck and find the lower intercooler boot. Now look at the frame. The drain is just on the other side of the frame and up. It will make a mess if you don't have heater hose to put on the little drain nipple.
Old 04-13-2013, 08:16 PM
RM2738's Avatar
RM2738
RM2738 is offline
I believe it's white or off white.
Old 04-15-2013, 07:40 AM
ktheavner's Avatar
ktheavner
Thanks Guys for info and the tip about putting a hose on the drain, It all drained rt into bucket NO MESS. Thanks again, KT.
mprsox
07-28-2019 01:12 PM
billb2000
13
10-23-2014 10:20 PM
hr404
10-03-2008 04:03 PM
afsigma21
1997-2006 Expedition & Navigator
04-09-2008 11:33 AM
flip418
08-10-2006 11:58 PM
Quick Reply: 2008 Radiator drain plug. Where is the thing?
