Drain Radiator
Old Apr 7, 2008 | 01:11 PM
afsigma21's Avatar
afsigma21
Drain Radiator
I need help draining the radiator. I want to do a complete fluid change, but cannot figure out how to drain it.
I do not see any drain plugs and the hose going to the lower engine block has this humunga metal clamp I cannot get off.
Any suggestions?
Old Apr 7, 2008 | 01:37 PM
buzzard's Avatar
buzzard
There's a draincock down at the bottom. Open it up and drain the radiator. What I like to do next is remove the t-stat and replace waterneck. Now fill radiator with water (actually fill degas bottle) and run engine with upper hose removed at radiator. Flush until only clean clear water comes out of hose. Drain radiator, replace t-stat, fill radiator with coolant and you're done.
Old Apr 7, 2008 | 05:32 PM
afsigma21's Avatar
afsigma21
I cannot find that drain for anything!
Old Apr 7, 2008 | 11:58 PM
sbclemens's Avatar
sbclemens
Look near the front of the passenger side wheel well. You'll find the drain **** there.
Old Apr 9, 2008 | 08:49 AM
afsigma21's Avatar
afsigma21
THAT did the trick, I was looking in all the wrong places. THANKS!
Now, where can I buy the Motorcraft Antifreeze.
Old Apr 9, 2008 | 10:54 AM
afsigma21's Avatar
afsigma21
Anyone use the Prestone 50/50 stuff that says can be used with any color / all types?
Is this OK on my 2001 Expy?
Old Apr 9, 2008 | 11:09 AM
berry1234's Avatar
berry1234
Why Motorcraft? Plenty of other qaulity anti-freezes out there. Prestone, Zerex, etc.
Old Apr 9, 2008 | 11:33 AM
buzzard's Avatar
buzzard
Just get good ole ethylene glycol ---- the green stuff ----- and mix with water at around 50% ratio.
mprsox
Jul 28, 2019 01:12 PM
cliffhanger45
Jul 2, 2011 03:09 PM
counie
1983 - 2012 Ranger & B-Series
Nov 10, 2006 09:40 PM
wavinwayne
Jun 7, 2005 12:14 PM
dallas01
Modular V10 (6.8l)
Mar 31, 2003 07:06 PM
