Daystar 2" Front Leveling Kit
Yes I believe you do, as you are still increasing the distance of travel. I added a ready lift 2" leveling kit and added longer front units to compensate. I looked up daystar site and found " If there are extra items required, such as longer shocks, it's clearly stated in the application description" so I guess it depends on the product. What kit are you looking at? FORD F250/F350 4WD 2005-12 COMBO KIT W/ 2-1/2"LEVELING KIT & SCORPION SHOCKS
You are correct Raptor. Also, per their website they only make a 2.5" for the 4x4 (which I have). I am assuming I would be ok (if I use the 2.5" leveling kit) to order my front Rancho's in +2.5" version? I may need to call Rancho on this one. I want to switch to 20" rims don't think their 1" leveling kit will be enough unless someone knows for sure. Thx!
