do i need a spacer on my carburetor?
I have a motorcraft 2150 carb on a 390 engine. I know isn't for my year truck.
I am coming from an autolite 2100 that needed a pcv spacer that is run from the breather.
When I got the 2150 I put it on with the spacer on there and plugged the pcv port on the carb.
I could not get the car to run more than 5 seconds before dieing. Huge vacuum leak! Found out its on the spacer by trying just using the thicker gasket below the carb no spacer car started and idled fine.
Is it OK to run like this? If not where can I get just a normal spacer for the 2150?
Thanks
Thanks
The purpose of the PCV is to evacuate crankcase gases/airborne oil mist and have it burned as part of the combustion cycle. Deleting the vacuum (ala the PCV, hose, and spacer) results in the oil becoming dirtier faster plus the carb has to be adjusted to exclude the air sourced from the crankcase.
There is more benefit to keeping a functioning PCV than deleting it in my opinion.
Burning crankcase gasses will do more harm than good for fuel economy, the only reason that stuff was ever put on from the factory is because of government being paid off by tree huggers. You should beable to plug the hole in your factory spacer, just make sure it is air tight. Otherwise check with a local parts store or Summit, I know I have seen them before.
A PCV valve (and its associated routing) is absolutely critical for the health of your engine. Do not remove it under any circumstances.
Whether you use a stand-alone breather on the opposite valve cover or run the breather line up to the air cleaner and install the breather there is up to you, but do not remove the system altogether.
But I concur with FMC400....
The alternative to an OEM PCV system is a crankcase evacuation system straight to the collectors with check valves as pictured below.
Installed:
The write-up: Crank Case Evacuation - Ford Muscle Forums : Ford Muscle Cars Tech Forum
For anyone scratching their head, the road draft tube can be seen coming off the valve cover on this Slant-6.
hooler1
02-28-2015 09:08 PM
kb4391
04-12-2009 07:27 PM
78bigunns
09-11-2008 12:03 PM
76supercab2
24
12-10-2006 04:50 AM
BB
10-25-2002 12:09 AM
