Scangauge/MPG/DP Tuner
I love the DP Tuner I just installed but it has really messed with my overhead MPG readout. MPG readings are in the upper 20's. I really miss the real time MPG readout and was thinking of getting a Scangauge II or e. Do you think the DP will affect the Scangauge as it did the overhead MPG display?
Also, why should I spend the extra bucks for the Scangauge II vs the E?
I just use the overhead MPG as a "pass-fail". My overhead averages 20.4 MPG under normal driving conditions. If I hit reset on a flat piece of road with no wind, I would expect the number to be higher after a little time (no accel or gear changing to bring it down). If it says 18 or 19, that's a fail... and a wrench appears in my crystal ball. I've had my lie-o-meter swing from accurate to 12 MPG over, depending on the predominant driving style of that tank and the tune.
