adventures in door pin removal
(this is copied from my project page)
ok i ended up buying the hinge pin removal tool from Classic Haulers. I then read on here about how mixed reviews of how well it worked.
I gave it a shot anyhow. I figured out that if you heat the hinge up real good on both top and bottom, then use the hinge pin puller it worked better.
I put good amount of pressure on the pin using the puller, then wacked straight up on the end of the bolt of the puller the pin moved and could be removed.
top hinge was way harder to do had to cut the head off and wack it down a bit then could force it upwards.
so with out any more of me blabbing here are pics
and i found out why my door wouldnt close. hopefully all the bent up part is in the door.
gsharum
03-26-2019 12:49 PM
Motolover
07-20-2018 09:30 PM
92 Red F150
20
02-10-2015 12:30 PM
flatheadjohn
02-03-2010 08:27 PM
