i believe i need a carb adjustment
Old 03-25-2013, 01:07 AM
kevancurtis's Avatar
kevancurtis
kevancurtis is offline
how do i adjust my carb on my 1965 econoline supervan its got a 240 with a FoMoCo single barrel
Old 03-25-2013, 01:09 AM
kevancurtis
oh and it has an electric fuel pump. do i need a inline regulator?
Old 03-25-2013, 01:10 AM
kevancurtis
it seems to smoke some and smells rich in fuel
Old 03-25-2013, 09:07 AM
hotstuff's Avatar
hotstuff
hotstuff is offline
the 1 bbl don't like a lot of fuel pressure , around 5 lbs. is plenty . check pressure add regulator if needed
Old 03-26-2013, 10:07 PM
kevancurtis
how do i test my fuel pressure?
Old 03-27-2013, 08:22 AM
kjhales's Avatar
kjhales
kjhales is offline
The shop manual specifies fuel pressure of 4 to 6 psi, and an unrestricted flow rate of 1 pint per 30 seconds or faster, and stresses the need for pressure to be in correct range. You likely need a pressure gauge to check it.
I also have a 1965 Econoline with a 240 and an electric fuel pump. My pump is the "Mr Gasket" available from Autozone for about $45. And the engine seems to be running a bit rich. The pump claims pressure to be in 4 - 7 psi range, but who knows what voltage they applied to the pump when testing it.
When I finish other tasks that are preventing me from passing inspection (I wanna get it on the road!!!), I may try dropping the voltage on the pump a little to see if that helps; a resistor is probably cheaper than a pressure regulator.
kjhales
rogerfries
12-07-2014 11:11 PM
pickenspolitics
01-23-2014 06:49 PM
79f150toy
01-04-2009 06:49 PM
85f-250-460
11-20-2003 07:03 AM
ken_tubbs
10-07-2003 11:27 AM
Quick Reply: i believe i need a carb adjustment
