Here's my Chevy column to AOD tranny linkage.
Here is how I ended up attaching my 1991 Chev Blazer steering column up to the 1991 T Bird AOD
Tranny I want to use. First off I have to say I don't like working with levers and geometry angles
and stuff. Hurts my head. I really wanted a cable system but for whatever reason Lokar does not
make a cable for my application. Therefor I come up with this hybrid system that uses the original
AOD shift cable as well as some Chevy linkage and a lever for lack of a better definition.
Whoa, not sure what happened there with the pic. I put a small write up in my gallery for anyone else who is dealing with this problem. It shifts smooth and easily through all of the gears. Here's how I secured the cable so it would pull the AOD shift linkage through the gears.
And heres what I used
That looks like an excellent piece of engineering. Very nice. My only thought or concern would be if there's enough flex if, by chance, the cab and frame flex differently so as to not cause a problem with pushing or pulling on the trans lever unwantedly. I'm guessing everything is close enough and having the cable portion it should be fine, but just something that popped into my mind and thought I'd share. Something to check on before its too late.
Remi
silar
20
05-19-2018 09:38 PM
ferguson777
17
07-24-2012 07:11 AM
Talman26
04-02-2003 05:49 PM
