89 f250 460 burning oil like crazy 4 quarts to a tank of gas
Old 03-23-2013, 10:10 AM
6.9idiatsturbo's Avatar
6.9idiatsturbo
6.9idiatsturbo is offline
I bought this truck off an old farmer a few weeks ago had been sitting I know 2 years it has 68,000 original miles on it truck runs great hasn't lost any power or anything but it burns oil bad with in 200 miles it will burn every bit of 4 quarts of oil it rarely smokes like it will only smoke if I get on it real hard. I just don't understand it why its doin it like its doin it. it runs strong hasn't lost any power at all
Old 03-23-2013, 10:16 AM
Bluethunder3320's Avatar
Bluethunder3320
Bluethunder3320 is offline
i would start by checking compression. can you see any leaks? what color are the spark plugs?
Old 03-23-2013, 10:23 AM
6.9idiatsturbo
When I Park it it doesn't leak anything on the ground at all. I haven't checked compression yet all the plugs looked good except for one. I have had quite a few trucks with big blocks in em this is the only one I have ever had problems out of. I have had a 94 fuel injected it didn't use a drop of oil at all the others were all older carb motors. I have been told the early fuel injected big blocks like this one was a common problem burning oil like this. I Kurt don't know if its worth trying to fix or if it would be better to pull this motor and get a mid 80s carb motor
Old 03-23-2013, 10:38 AM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
I'm sure that if the truck was sitting, the rings on at least one cylinder siezed into the wall and when you started it they broke loose and are letting all kinds of oil through. You should definitely check compression.
Old 03-23-2013, 04:11 PM
Dr. Driveway's Avatar
Dr. Driveway
Dr. Driveway is offline
That's what I was thinking. One of those rings was probably bonded to the cylinder wall when that thing was first started up and it broke that ring. If it is an oil ring, it will probably still get good compression, but that cylinder wall is probably getting scored up while it is running.
Old 03-23-2013, 05:43 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Why are there 2 threads on this?
6.9idiatsturbo
03-24-2013 10:21 AM
6.9idiatsturbo
03-23-2013 11:29 PM
kadrocker
12-14-2009 09:41 PM
kcb37
06-29-2006 11:06 PM
qhnut
13
06-26-2006 09:06 AM
Quick Reply: 89 f250 460 burning oil like crazy 4 quarts to a tank of gas
