what do i need to know on how to rebuild my 4.6 motor
i have a 97 ford f150 with a 4.6L engine in it and it has a bent wrist pin and possible some spun bearings on the crank, i was planning on just buying a whole new motor for the truck but it seemed to expensive and i figured rebuilding the motor would be cheaper. i need to know the basics about what to do so i can rebuild it. ASAP!
Welcome to FTE.
I note you are in Iowa.
Serving suggestion:
--Do you have smog inspections now or are you looking at them in the future?
IF NOT,
Look into a later 4.6. More power.
As for the rebuild, the first thing you need to know is if it is even rebuildable. The damage you describe often results in ruined cranks and cracked blocks and/or heads.
Serving suggestion:
IF NOT,
Welcome to FTE.
Serving suggestion:
IF NOT,
Serving suggestion:
IF NOT,
Have you rebuilt and engine before?
How to Rebuild 4.6-/5.4-Liter Ford Engines: George Reid: 9781613250433: Amazon.com: Books
i am ordering the book here in acouple days i have an engine stand and i am working up the money for parts and tools. what do i need a cherry picker for?
Purchased the 'Rebuild Small Block Engines', same author/publisher and pleased, found the book very thorough. It takes you though the entire process step by step of a rebuild, what to look for in determining if the engine is rebuildable, etc. Check w/ 'bookfinders.com' and it appears all the used/new books listed are going for around the same price as the referral posted.
