Wires
Old 03-14-2013, 07:45 AM
K9sicem's Avatar
K9sicem
K9sicem is offline
Wires
I need a little help with where these wires go.
The engine ran great until I put the the new (GM) alt on. Now it will not fire. I chased a few wires and found several that may be shorting out. I unhooked the Alt just in case that was the problem. Still no go.
Old 03-14-2013, 10:28 AM
blackedout's Avatar
blackedout
blackedout is offline
#1 should go to your ignition switch 12V from the battery.
#2 energizes the coil from the ignition switch to start the truck.
#3 should go to the positive of your coil.
Hope this helps.
rlay302
12-08-2012 02:58 PM
Scolesy8
3.0L V6
12-23-2008 09:18 PM
ken selvy
02-21-2006 03:22 PM
Fordbronco95
1978 - 1996 Big Bronco
10-29-2005 10:30 AM
sibbles
09-13-2005 09:11 PM
Quick Reply: Wires
