Vacuum leak
Old 03-13-2013, 08:26 PM
SiscoKid's Avatar
SiscoKid
SiscoKid is offline
Vacuum leak
My 89 f-150 4.9 300 6 cyl has a vacum leak. From the gas tank, to under the hood from along the frame rail, the vacum line is missing. And i recently discovered a line running of the transmission that has. been plugged off about 5 inches from the tranny. Dont know where it goes I would love to get this fixed, so my truck stops running like crap. Anyone have a diagram for dummies that could help me reconfigure the vacuum line setup? Also, there is a small diameter tube running from the engine to the exhaust, just before the cat. Anyone know what that is and the purpose it serves? Whatever it is, has rotted off and makes for a horrible exhaust leak, and makes my truck sputter and **** like crazy. And quite possibly the best way to fix it? A combination of vacuum line leak and exhaust failure is driving me nuts! Please help...
Old 03-13-2013, 08:34 PM
subford's Avatar
subford
subford is offline
Sounds like the vacuum line the goes on the back of a C6 transmission (TP vacuum motor).
Old 03-13-2013, 08:38 PM
DBGrif91's Avatar
DBGrif91
DBGrif91 is offline
Can't help you on the vac diagram.
The tube that hooks into your exhaust is part of the air pump system. I don't know the details of how it works, but at given times the valve it hooks into will open and the air pump will shoot extra air into the exhaust.
The way I fixed mine was I cut a chunk of 3/4" electrical conduit and welded it onto the tube. It's not 100% leak free by any means, but it's certainly better than it was.
Old 03-13-2013, 08:50 PM
SiscoKid's Avatar
SiscoKid
SiscoKid is offline
Soo, from the back of the trans to a vaccum motor?
Old 03-13-2013, 08:53 PM
SiscoKid's Avatar
SiscoKid
SiscoKid is offline
Nice fix idea on the air pump system... Did your truck run badly when that tube was separated from the exhaust??
Old 03-13-2013, 08:56 PM
subford's Avatar
subford
subford is offline
No the vacuum motor is screwed into the back of the C6 Transmission and the vacuum line runs from there to the vacuum source on the engine.
This vacuum line tells the Transmission the throttle position or the load on the engine.
Old 03-13-2013, 09:07 PM
SiscoKid's Avatar
SiscoKid
SiscoKid is offline
Thanks, that helps alot. Would you know where to find locality of the vacuum source at the engine from the trans?
Old 03-14-2013, 08:20 AM
subford's Avatar
subford
subford is offline
It hooks to the Engine Vacuum Distribution Block.
JoeS.
1999 to 2016 Super Duty
07-22-2015 03:07 PM
gweeds
05-11-2008 03:22 PM
rbmstng
03-04-2003 12:05 PM
JW 4x4
01-16-2002 04:56 PM
Quick Reply: Vacuum leak
