Sponsored by: Real Truck
Vacuum leak
Old Jul 20, 2015 | 08:57 PM
JoeS.'s Avatar
JoeS.
Vacuum leak
I have a V-10 in my Y2K F-250. Under the throttle body there is an elbow on a vacuum line that is badly cracked. I went to parts store and bought a heater line that fit both ends (different sizes) but isnt the exact angle of the original. It fixed the hissing vacuum leak but now it is running pretty rough. Doesnt seem to be pinched but it's definitely different. The poor performance during acceleration wasnt a problem before but is very noticeable now. Could the line being different effect the performance?
Laser pointer is touching the bad elbow in this pic.
Old Jul 20, 2015 | 08:59 PM
JoeS.'s Avatar
JoeS.
I have the bettery disconnected now trying to let the computer reset so the check engine light goes off. Hoping that maybe the computer is still trying to compensate for the vacuum leak that isnt there anymore. And hoping that when reset it will level out.
Old Jul 20, 2015 | 09:01 PM
projectSHO89's Avatar
projectSHO89
You still have a vacuum leak, perhaps a new one from working around the old tubing.
Make sure you check that PCV hose elbow all the way back in the back.
Old Jul 20, 2015 | 09:14 PM
JoeS.'s Avatar
JoeS.
Will do. Check engine light is off but it's still running rough. And now there is an odor almost like an exhaust wihen the cat is getting full. Kind of a sulfur-ish smell.
Old Jul 21, 2015 | 05:57 AM
projectSHO89
That indicates excessive unburned fuel is getting dumped into the exhaust. Usually caused by either a 1) vacuum leak or 2) misfire or 3) leaky injector(s).
Old Jul 21, 2015 | 06:34 AM
JoeS.'s Avatar
JoeS.
Thanks! I'll check the PCV. A buddy told me last night to use a temp scanner to see if there's a large difference on either side of the cat and that may indicate a clog.
Old Jul 22, 2015 | 03:07 PM
JoeS.'s Avatar
JoeS.
Vacuum leak and a bad boot ended up being the problem. I believe i'm going to put a high flow pipe, er, cat and maybe a muffler of some sort on it next.
Are yall seeing any benefit from putting a program on your early V-10's?
miked79928
1997 - 2003 F150
Mar 6, 2017 11:13 AM
4x41977
Sep 27, 2012 11:07 AM
59shortbed
1997 - 2003 F150
Dec 15, 2007 07:50 PM
DBray6
Feb 5, 2007 10:16 AM
