voltage readings?
Old 03-10-2013, 11:51 AM
mustang9701's Avatar
mustang9701
mustang9701 is offline
voltage readings?
Can anyone help with the voltage readings on a 2001 7.3?
Koeo
Idle , things like that?
My dads battery light flickers occasionally, not always.
Old 03-10-2013, 12:36 PM
koski19's Avatar
koski19
koski19 is offline
Koeo
I repaired a 99 electrical system last week for the same symptoms.
I removed the alternator and bench tested it at the local auto parts store.
Alternator checked good. I then load tested the batteries and cleaned the terminals. They too, tested good. I then inspected battery cables for corrosion. Checked OK. I then replaced the belt tensioner and idler pulley. They had 158,000 miles on the original Ford parts. I assumed that after 13 years of service and 158,000 miles the spring no longer held the correct tension for the alternator. After installation the flickering light ceased and has not come back on. Alternator output 14.0 to 14.5 amps. 2001 should be similar. Hope this helps.
Jeff
Old 03-10-2013, 01:28 PM
mustang9701
Thank you. Im only reading 13.4 at idle but all tested good. It does only happen when cold though
Old 03-11-2013, 06:44 AM
koski19's Avatar
koski19
koski19 is offline
13.4 at idle is marginal in my opinion. I would take it off and have it bench tested. Here's a link that should help:
Jeff
Old 03-11-2013, 08:34 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,108 Likes on 2,168 Posts
push down on the little two wire plug on the alternator, and the light should go out.
Old 03-11-2013, 08:44 AM
Tugly's Avatar
Tugly
Tugly is offline
This is out there a bit, but GPRs have been acting up lately. It's possible the glow plugs are coming on when they shouldn't.
marcogyver
1997-2006 Expedition & Navigator
12-31-2012 11:35 AM
cak301
07-23-2011 12:33 AM
Dorsai
04-10-2011 08:47 AM
Chipmm
Electrical Systems/Wiring
07-07-2004 11:34 AM
94Bronco58
1978 - 1996 Big Bronco
18
01-20-2004 11:00 PM
Quick Reply: voltage readings?
