Voltage Charging issue
Old Dec 29, 2012 | 02:18 PM
marcogyver's Avatar
marcogyver
In October my battery failed and I was told there was a bad cell from a faulty alternator. The battery was swapped and I changed the alternator and belt. There was an issue locating the correct alternator because the pulley widths wouldn't match 8 vs 6 ribbed. I now notice the headlight dim at idle and the voltage is 12V until you rev above idle which generates 13.8 to 14V. I have a 02 Expy AWD. From what I see by the part number is a 130amp.
Old Dec 29, 2012 | 02:50 PM
OverReved's Avatar
OverReved
How many miles on the alternator? The brushes may be worn down. If you catch them before they gouge the slip rings, you might get away cheap by just having to replace the brushes. While you have them out, have the voltage regulator checked. Good luck
Old Dec 29, 2012 | 03:18 PM
marcogyver's Avatar
marcogyver
Battery and alternator were both replaced this October so there shouldn't be anything else in the circuit? The belt isn't slipping and also was changed.
Old Dec 29, 2012 | 03:38 PM
JWC 3's Avatar
JWC 3
Bad regulator , and or plug .
Old Dec 29, 2012 | 03:57 PM
marcogyver's Avatar
marcogyver
Thanks, just would like to ask, both are within the alternator?
Old Dec 29, 2012 | 04:05 PM
JWC 3's Avatar
JWC 3
Regulator is in alternator . Plug connects alternator to truck . Ck conditon of plug terminals . Most likley you need to replace alt. Hope you have a warranty . I have put them on to only have them fail a week later .
Old Dec 29, 2012 | 10:07 PM
Moto Mel's Avatar
Moto Mel
I had a similar problem with my Navigator and I bought a new, not remanned alternator and had the same recurring problem. I kept taking them back until I got a good one. Autozone was not happy with me and I was really tired of changing the alternator. I did get pretty good at it though.
Old Dec 30, 2012 | 05:01 PM
madsonp's Avatar
madsonp
If you do get another alternator, have them bench test it before you leave the store, I've gotten bad ones right off the shelf a number of times, also I suggest getting one from Napa or a similar store as they tend to be a little better quality. The ones from the Auto Zone type store are a cheap as you can get.
Old Dec 30, 2012 | 05:27 PM
JWC 3's Avatar
JWC 3
I agree . And have them test it at least 6 times ! The bench tester does not load them as your truck does . I was in NC recently with a failed alternator and when it cooled off and I got it to the "parts store " It bench tested good ! I showed my ASE ct. And told the guy to test it more . He was Pissy and said the machine did not lie ! After I got the manager involved they tested it 6 times , on the 6'th it burnt the kids hand and failed ! They gave me a new one and an apology !
Old Dec 31, 2012 | 10:00 AM
marcogyver's Avatar
marcogyver
Thanks for all the input. When I went back to PepBoys and explained the situation they said the 02 was a split year on the build and I needed an 03 alternator which was not correct. They were all over the place looking of for the correct alternator. The only issue with the called out part for the 02 Expy was the 8 rib pulley, so finally I had them take my 6 rib pulley and swapped it off the new alt.
After installing things look great but I hope it lasts. I wish I checked back on the forum before I went there because I would like to have it tested before hand. How long does a single alternator test take?
Old Dec 31, 2012 | 11:35 AM
Moto Mel's Avatar
Moto Mel
[quote=marcogyver; How long does a single alternator test take?[/quote]
Maybe a minute if they are slow moving.
Tjdb2000
Apr 9, 2019 02:15 PM
Hound Dog Lew
Jun 7, 2017 08:32 AM
jfoltz
Mar 20, 2010 02:05 PM
94Bronco58
1978 - 1996 Big Bronco
18
Jan 20, 2004 11:00 PM
doman24
Aerostar
Jan 9, 2004 02:28 PM
