Cig Lighter
Old 10-20-2004, 04:32 PM
jamesj's Avatar
jamesj
jamesj is offline
Cig Lighter
I have 2000 ex , I want to replace the cigarette lighter receptacle on the front below the cup holders, somehow I have the problem of unscrewing the nut that holds the receptacle and also I am not able to disconnect the connector to the receptacle. Anyone has done this before? Do I need a special tool to unscrew the nut from the recep? If I use the cigarette lighter it blows the fuse. Thanks for any input.
Old 03-10-2013, 12:28 AM
DBubba's Avatar
DBubba
DBubba is offline
Really old post, but having problems with that receptacle but it slides right out. Were you able to find a replacement?
Old 03-10-2013, 01:58 AM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
Wow... This post is OLD!
Old 03-10-2013, 11:30 AM
wpnaes's Avatar
wpnaes
wpnaes is offline
More often the problem is keeping the receptacle in the dash. A well placed hose clamp will do the job.
Old 03-10-2013, 04:08 PM
Immortal_Ben's Avatar
Immortal_Ben
Immortal_Ben is offline
I would be amazed if this person was still an active member. Super low post count.
Bigtom04
01-14-2016 01:59 PM
whiteboyslo
11-08-2014 05:03 PM
McCoyaz
Electrical Systems/Wiring
05-27-2014 08:26 PM
ten70man
1997 - 2003 F150
11-11-2010 12:12 AM
wedge88
1999 to 2016 Super Duty
06-09-2009 09:55 PM
Quick Reply: Cig Lighter
