2wd to 4wd on an OBS truck
Old 03-04-2013, 06:25 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
'94IDITurbo7.3 is offline
let's just say for a minute that a certain someone wants to put a D60 under the front of their truck.
i know that you need the 4x4 trans(auto in my case) b/c you need to swap out the tail housing and the output shaft on the trans, obviously the axle, springs, ect. from a short bit of research it seems that an RSK kit is pretty much a straight bold on deal for the front of the 2wd frame. From the sounds of it the PMF RSK kit is one of the better ones to go with.
First off, does anybody have any links to 2wd-4wd on an OBS truck? i have seen the recent thread for a slant nose truck but the front of the frame are different. i have also seen a guy do a D50 ttb into his 2wd truck, but since he used the ttb he couldn't use the rsk therefore is different from what i need. ttb to D60 swaps don't help me much since that is a simple bolt in deal not an entire conversion.
Is it true that the RSK kit is a simple bolt on to the front of the frame?
How many holes need to be drilled in the frame for the rear hangers/shackles, if any?
Any help would be great!
Old 03-04-2013, 06:48 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
i have one suggestion and then i'll leave ya alone lol.run her 2wd and enjoy it for what it is.meanwhile rather than invest anymore time and money,start tucking away the $ for that 4wd whistling turboed 6.0l truck that you really want instead.the sooner you start saving,the sooner it becomes a reality.
this might help you out;
https://www.ford-trucks.com/forums/9...ng-d-50-a.html
Old 03-04-2013, 07:17 PM
akamacgyver's Avatar
akamacgyver
akamacgyver is offline
Clueless spectator!
Eric,
I'm with Ford on this one, except for the 6.0 thing, I know you like them, but I've seen too many $4000.00 repair bills to take a chance on one. As you know, I just picked up the 90 F350 for a little more than the price of a D60 and RSK, and even though I have a lot of work to do making it how I want it, I will end up with an extra trans, block, trans case, and all the other parts that a donor truck gives you, with no redneck engineering required. Start socking your money away, and buy yourself a 4X4.
Mac.
Old 03-04-2013, 08:47 PM
'94IDITurbo7.3
yeah i know what you guys mean and trust me i would much rather have a 4x4 six than have this truck 4x4. although by the time i can even start to think seriously about a 6.0l they will be dinosaurs lol.
keep talking to me like this. i am almost convinced to keep it 2wd lol. This was all my dad's idea btw lol. for some really odd reason he is dead serious about this. i'd rather just save the time/money/effort and buy some new projector HID head lights seeing as how my stock lights are on the verge of dangerously dim.
Old 03-04-2013, 08:49 PM
'94IDITurbo7.3
double post
Old 03-04-2013, 10:00 PM
RacinNdrummin's Avatar
RacinNdrummin
RacinNdrummin is offline
Eric, my advice would be to have a goal, and shoot for it. If you want to keep this truck at least for awhile, then do it, its at worst a learning experience like the rest of it has been.... If you put a D60 in it, the resale will be much higher than if you were to leave it 2wd, so when you do go to sell it, you will already have more of a head start.
On the otherhand, converting a 2wd truck isnt nearly as easy as doing a D60 swap on a D50 truck... So just be ready if you do.
Old 03-04-2013, 10:27 PM
tecgod13's Avatar
tecgod13
tecgod13 is offline
Have you searched the other 2wd to 4x4 threads? they're pretty numerous.
Its a pain in the ***. If you want to know more about the pain in the *** part, read the threads.
If you have time and money to spare, do what you want, but its probably not worth your time, or money.
Old 03-05-2013, 01:19 AM
NMB2's Avatar
NMB2
NMB2 is offline
I'm starting mine soon....links though, not leaves
Old 03-05-2013, 01:58 PM
'94IDITurbo7.3
that was my thought and my dad's thought about it. IF i can get a complete donor truck(that would be ideal) then take what i need from it then part it out(unfortunately i would be taking probly the most valuable thing off of it though lol) and hopefully make up some of the swap cost, maybe even all of it but i'm not holding my breath on breaking even lol. And we did talk about the added value of the 4x4 on resale. Honestly right now i think it would be the smartest for me to keep the truck, at least economically lol. in a couple months i will be done with school......for now and then i won't be driving the royal crap ton of miles that i do now so that will help with fuel savings as well.
so kind of like a dodge 4x4 front axle set up?
Old 03-05-2013, 05:08 PM
'94IDITurbo7.3
well that didn't last long......this project WILL NOT happen lol.
I looked in my bank account.....nuff said.
Old 03-05-2013, 08:00 PM
Red454sedgwick's Avatar
Red454sedgwick
Red454sedgwick is offline
Sorry guys i'm no good with abrriveations, what dose obs stand for. I'm going to make my tow truck in to a 4x4, but I'm just going to a indepent front using the coil springs that it alrady has so I don't have to modify the frame.
Old 03-05-2013, 08:36 PM
Phy's Avatar
Phy
Phy is offline
OBS is old body style.
Old 03-06-2013, 01:52 PM
'94IDITurbo7.3
how do you plan on re-using the 2wd coil springs and radius arms in a 4wd system. It would be easier to go with a solid axle and leaf springs rather than mess with the coil springs and radius arms
Old 03-06-2013, 06:24 PM
Red454sedgwick
the frame is diffrent, I would have to hack into it to put in leaf springs. I think, I haven't got out the tape meauser yet. That the radius arms will bolt on to the indpenadnt front four wheel drive axle, if they don't I was going to use a f150 raduius arms. They all look the same everything should bolt in.
Old 03-06-2013, 07:21 PM
'94IDITurbo7.3
the only hacking of the frame that is needed would be boxing in the frame rails at the front and drilling some holes on each side for the rear hangers.
If you went with the RSK then you would just box the front in and then bolt the RSK to the frame like you would a truck that was 4x4, then just drill the holes.
Quick Reply: 2wd to 4wd on an OBS truck
