1986 F150 neutral safety switch wiring diagram
I have a 1986 351W and C6 sitting in my 55 F100. Installing new wiring harness and looking to wire the NSS. Does anyone happen to have a wiring diagram of that switch? I think the switch doubles as the NSS and back up lights is that correct?
thanks
thanks
Not all trucks have the NSS is combined with B/U light switch. Those that do, the switch is half moon shaped and mounted to the drivers side of the C6 and has 4 wires. Others like me have a plunger type NSS in the steering column, and the B/U light only mounted to the side of the Trans. Looks just like the combo switch but only has 2 wires.
ctubutis You are correct on the color coding for both and just made my day after giving up on the reverse light combo today as i had 5 wires opposite of those to contend with and decided to check here as well. I needed to remove the entire NSS to rewire for a B & M Hammer and it cannot stay on the tranny and needed to wire reverse/NSS direct to shifter switches, also Please note that this combo continues true through 1999 my year truck, not sure how much later though. Thanks again
Truxx1956
08-22-2008 03:31 PM
salty4568
Electrical Systems/Wiring
01-22-2004 07:42 PM
