6.2L V8 Discuss the 6.2L V8
2 different 6.2s???
Old 02-20-2013, 12:03 PM
sundance1's Avatar
sundance1
sundance1 is offline
2 different 6.2s???
I was looking at the specs for the 6.2 in the Superduty and it showed 385hp and 405tq but the specs for the 6.2 in the F150 shows 411hp and 434tq for that 6.2. Why would they put a less powerful version 6.2 in the Superduty? What am I missing?
Old 02-20-2013, 03:09 PM
8iron's Avatar
8iron
8iron is offline
The 6.2 in the f150 gets a hotter cam and ratings are with high octane premium gas. 6.2 in the SD's are slightly detuned for longevity under heavy use.
Old 02-20-2013, 03:58 PM
RAPR's Avatar
RAPR
RAPR is offline
what 8iron said is exactly correct. With it mainly being used to pull loads, it is expected that the truck will likely be running at elevated rpm's for extended periods. Ford wanted the engine to be able to handle this type of abuse. Also, with Ford having the idea in mind that most of the F-250 6.2L trucks would probably be company fleet trucks, they want to make sure they would last...regardless of the abuse the driver gave it.
I use to be provided a company vehicle for work/personal use, and even I had the tendency to ride it hard and hang it up wet. That is just the nature of how a company vehicle ends up being treated, since the drive does not have any ownership of the vehicle and doesn't care about getting 2mpg having a company gas card.
Old 03-05-2013, 11:56 PM
WhiskeyTangoFoxtrot's Avatar
WhiskeyTangoFoxtrot
WhiskeyTangoFoxtrot is offline
<table class="specsTable" cellSpacing="0" cellPadding="2"><tbody><tr class="specsRow_1"><td id="cell_1_22" class="bluecell" colSpan="1">
</td><td id="cell_2_22" class="tancell" colSpan="1"> </td><td id="cell_3_22" class="tancell" colSpan="1">
</td><td id="cell_4_22" class="tancell" colSpan="1">
This is for under (385hp) vs. over 10,000 GVWR. 6.2L
2013 Ford Super Duty | View Full Engine Specifications | Ford.com
<table class="specsTable" cellSpacing="0" cellPadding="2"><tbody><tr class="specsRow_1"><td id="cell_1_22" class="bluecell" colSpan="1">Horsepower/rpm
</td><td id="cell_2_22" class="tancell" colSpan="1"> </td><td id="cell_3_22" class="tancell" colSpan="1"> 385 @ 5500 316@ 4179
</td></tr><tr class="specsRow_2"><td id="cell_1_23" class="bluecell" colSpan="1">Torque lb.-ft./rpm
</td><td id="cell_2_23" class="tancell" colSpan="1"> </td><td id="cell_3_23" class="tancell" colSpan="1"> 405 @ 4500 397 @ 4179
</td><td id="cell_4_23" class="tancell" colSpan="1">
</td></tr></tbody></table>
</td></tr><tr class="specsRow_2"><td id="cell_1_23" class="bluecell" colSpan="1"></td><td id="cell_2_23" class="tancell" colSpan="1"> </td><td id="cell_3_23" class="tancell" colSpan="1">
Old 03-06-2013, 09:36 AM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
The 6.2 in the SD lineup has the same hp/tq, just rated at different RPM's for our wonderful folks at the EPA...
Old 03-06-2013, 10:09 PM
WhiskeyTangoFoxtrot
Got it. Thanks. I wondered about that.
Old 11-06-2013, 12:27 AM
moosesp's Avatar
moosesp
moosesp is offline
Confused?
Okay, so I'm a little confused. It states an under 10,000 gvwr hp rating and an over 10,000 gvwr rating. Are the engines in the trucks over 10,000 gvwr de-rated even further with only 316 hp and less torque. I sure hope this isn't the case because I just ordered an F350 with the 6.2 liter.
Old 11-06-2013, 03:33 AM
ATP Pilot's Avatar
ATP Pilot
ATP Pilot is online now
Nope, its the same engine and tune. The over 10,000 has a rating taken at lower RPM...different measuring standard for the heavier truck.
ITS THE SAME ENGINE on the over 10,000!
Old 11-06-2013, 09:37 PM
moosesp's Avatar
moosesp
moosesp is offline
Thank you for clarifying this! I feel way better now about my decision.
Old 11-06-2013, 10:39 PM
Flatbed Ed's Avatar
Flatbed Ed
Flatbed Ed is offline
you are correct. Same motor,just rating tested a little differently.
I think the Raptor does have a hotter cam though.
Old 11-06-2013, 11:32 PM
BossGasser's Avatar
BossGasser
BossGasser is offline
It's a hot rod engine in the F350. You will like it!
Old 11-20-2013, 08:29 PM
fstrthnu373's Avatar
fstrthnu373
fstrthnu373 is offline
also you got to realize that engines are rated on the dyno fully dressed with accessories the f-150 has electric cooling fans and the super duty has a huge mechanical fan. Im sure that plays a part.
Old 11-20-2013, 09:38 PM
Powelligator's Avatar
Powelligator
Powelligator is offline
Sounds like an opportunity for a performance increase!
By the way, if you get the 6.2 and throw in the 4.30 gears, you can get serious "all the way down the street" rubber if you hit the switch on the dash that defeats the traction control and hit the other switch that puts the tranny in Tow/Haul mode.
Not that I would have ever done such a thing, of course!
-Joe (now looking for Raptors to pick on...)
Old 11-20-2013, 10:20 PM
Flatbed Ed's Avatar
Flatbed Ed
Of course !
Yeah I have noticed the same thing. I often turn off traction control because my truck is faster with it off. No doubt.
Turn off T/C, turn on tow/haul, and knock it down to 3 speeds, then, hold on tight..........................!
todrobcon
1999 to 2016 Super Duty
22
09-23-2010 11:34 AM
6LPSD
01-31-2008 09:21 PM
Megalodon1
Ford vs The Competition
28
01-08-2005 08:40 AM
kspilkinton
02-10-2003 07:17 PM
Quick Reply: 2 different 6.2s???
