2 different 6.2s???
I was looking at the specs for the 6.2 in the Superduty and it showed 385hp and 405tq but the specs for the 6.2 in the F150 shows 411hp and 434tq for that 6.2. Why would they put a less powerful version 6.2 in the Superduty? What am I missing?
The 6.2 in the f150 gets a hotter cam and ratings are with high octane premium gas. 6.2 in the SD's are slightly detuned for longevity under heavy use.
what 8iron said is exactly correct. With it mainly being used to pull loads, it is expected that the truck will likely be running at elevated rpm's for extended periods. Ford wanted the engine to be able to handle this type of abuse. Also, with Ford having the idea in mind that most of the F-250 6.2L trucks would probably be company fleet trucks, they want to make sure they would last...regardless of the abuse the driver gave it.
I use to be provided a company vehicle for work/personal use, and even I had the tendency to ride it hard and hang it up wet. That is just the nature of how a company vehicle ends up being treated, since the drive does not have any ownership of the vehicle and doesn't care about getting 2mpg having a company gas card. |
<table class="specsTable" cellSpacing="0" cellPadding="2"><tbody><tr class="specsRow_1"><td id="cell_1_22" class="bluecell" colSpan="1">
</td><td id="cell_2_22" class="tancell" colSpan="1"> </td><td id="cell_3_22" class="tancell" colSpan="1"> </td><td id="cell_4_22" class="tancell" colSpan="1"> This is for under (385hp) vs. over 10,000 GVWR. 6.2L from: 2013 Ford Super Duty | View Full Engine Specifications | Ford.com <table class="specsTable" cellSpacing="0" cellPadding="2"><tbody><tr class="specsRow_1"><td id="cell_1_22" class="bluecell" colSpan="1">Horsepower/rpm </td><td id="cell_2_22" class="tancell" colSpan="1"> </td><td id="cell_3_22" class="tancell" colSpan="1"> 385 @ 5500 316@ 4179 </td><td id="cell_4_22" class="tancell" colSpan="1"> </td></tr><tr class="specsRow_2"><td id="cell_1_23" class="bluecell" colSpan="1">Torque lb.-ft./rpm </td><td id="cell_2_23" class="tancell" colSpan="1"> </td><td id="cell_3_23" class="tancell" colSpan="1"> 405 @ 4500 397 @ 4179 </td><td id="cell_4_23" class="tancell" colSpan="1"> </td></tr></tbody></table> </td></tr><tr class="specsRow_2"><td id="cell_1_23" class="bluecell" colSpan="1"></td><td id="cell_2_23" class="tancell" colSpan="1"> </td><td id="cell_3_23" class="tancell" colSpan="1"> </td><td id="cell_4_23" class="tancell" colSpan="1"> </td></tr></tbody></table> |
The 6.2 in the SD lineup has the same hp/tq, just rated at different RPM's for our wonderful folks at the EPA...
Got it. Thanks. I wondered about that.
Confused?
Okay, so I'm a little confused. It states an under 10,000 gvwr hp rating and an over 10,000 gvwr rating. Are the engines in the trucks over 10,000 gvwr de-rated even further with only 316 hp and less torque. I sure hope this isn't the case because I just ordered an F350 with the 6.2 liter.
Originally Posted by moosesp
(Post 13710481)
ITS THE SAME ENGINE on the over 10,000! :-drink |
Originally Posted by ATP Pilot
(Post 13710575)
Nope, its the same engine and tune. The over 10,000 has a rating taken at lower RPM...different measuring standard for the heavier truck.
(Post 13710575)
ITS THE SAME ENGINE on the over 10,000! :-drink I think the Raptor does have a hotter cam though. |
(Post 13710481)
also you got to realize that engines are rated on the dyno fully dressed with accessories the f-150 has electric cooling fans and the super duty has a huge mechanical fan. Im sure that plays a part.
Originally Posted by fstrthnu373
(Post 13762648)
By the way, if you get the 6.2 and throw in the 4.30 gears, you can get serious "all the way down the street" rubber if you hit the switch on the dash that defeats the traction control and hit the other switch that puts the tranny in Tow/Haul mode. Not that I would have ever done such a thing, of course! -Joe (now looking for Raptors to pick on...) |
Originally Posted by Powelligator
(Post 13762913)
Sounds like an opportunity for a performance increase!
By the way, if you get the 6.2 and throw in the 4.30 gears, you can get serious "all the way down the street" rubber if you hit the switch on the dash that defeats the traction control and hit the other switch that puts the tranny in Tow/Haul mode. Not that I would have ever done such a thing, of course! -Joe (now looking for Raptors to pick on...) Yeah I have noticed the same thing. I often turn off traction control because my truck is faster with it off. No doubt. Turn off T/C, turn on tow/haul, and knock it down to 3 speeds, then, hold on tight..........................! |
