Fuel sending units with plastic floats?
Hi folks, many years ago I replaced the original sending unit in my aft tank with a replacement from JBG. I really enjoyed having a gas gauge again, until about a week later the float developed a pinhole leak, and I literally watched the needle fall as the float filled with gas and fell to the bottom of the tank permanently.
At the time I didn't feel like dropping the tank again, so I've left it ever since. I finally feel like replacing it (looking at Rock Auto this time), and I do see the standard brass float model made by Dorman, but I also see a model by a brand called "Spectra" that appears to use a plastic float for only a dollar more. I assume the plastic float would be one piece and would be better, since the two-piece brass floats can leak at the solder joint. Has anybody used a plastic float, or heard of this brand? I'm curious if they're any good; I'd hate to drop the tank a third time!
Brass float (Dorman):
Plastic float (Spectra):
I've heard of the Spectra brand but don't have any personal experience with them. From what I have heard about them, the sending unit has a 5/16" hose nipple instead of the 3/8" that our trucks use.
If your sending unit is okay, Dennis Carpenter has replacement floats that will never leak. P/N 68-9275-S $5.00
Thanks for your input Mike; I happened to find it on Amazon as well and saw similar complaints about the hose fitting being the wrong size. Seems like a pretty important thing not to mess up when designing a replacement part. I am going to stay away. Thanks for the link; I had not thought to replace just the float. I guess they just snap in and out? I'll be picking one of these up from DC.
sorry for hijacking......i have the same sending unit, with the brass float. sometimes works, sometimes doesnt. what i wondered, is why mine has some kind of rubber boot that slips onto the float, covers most of the brass, but not all. what is the boot for???
thanks.............
thanks.............
Depending on how heavy it is, I think the boot could also throw off the gauge reading.
BBrown1017
13
06-15-2018 11:24 AM
elroy6468
05-13-2015 04:23 PM
66crawler
03-12-2012 02:01 AM
rmalottwtes30
15
04-24-2008 12:20 PM
victorcharlie
08-09-2004 08:11 PM
