Dyno results
Full Force 160/100%
Stock airbox
Stock exhaust (straight through 95-97 muffler)
Stock high pressure oil pump
Stock turbocharger
Stock transmission
Stock
Stock
Aftermarket tuning.
7/12 - 402 RWHP
I'll add to this discussion in a few weeks when I change nothing but the injectors and tuning (again).
Stock airbox
Stock turbocharger
Stock transmission
Stock
Stock
Aftermarket tuning.
7/12 - 402 RWHP
Full Force 250/200%
GTP38R
AFE Stage II
4" MBRP
BTS Trans
Fuel bowl delete w/RR and Walbro pump
Stock HPOP
Stock PMR bottom end
Stock springs
Stock pushrods
Stock head bolts
Self tuned using Minotaur
478/851 back in July on Hallers, with some boost leaks (fixed since then)
If I can get my rear diff fixed soon, I might throw it back on the dyno here in a few weeks. I'm curious to see if I can hit 500 hp after repairing the boost leaks.
GTP38R
AFE Stage II
4" MBRP
BTS Trans
Stock HPOP
Stock springs
Stock pushrods
Stock head bolts
we did the dyno at No Limit Tuning and Design, He is suppose to be e-mailing the results along with all the data logging, when he does I will post it up..I feel that I am leaving 50-60hp on the table somewhere, at least thats what I am getting from another site..I will be sending the data sheets to Jody for his review.Its interesting because on Full Force website the 238/100 is good for 480-500hp which puts me inline but several people with the same injectors are reporting 550-575hp. Kinda of the reason for this thread..
on
Last year at RRE, first time on a dyno so not overly confident in my numbers because I don't think I did my part correctly. However, with the setup in my signature minus the van turbo and ported housing (stock turbo with WW), in PHP 65Tow tune I came away with:
328 hp
704 lb/ft
I really screwed up my run in the 120race tune, so the numbers were too inaccurate to consider.
I plan to hop on again at RRE this year, and hopefully I will get some numbers I am more confident in.
328 hp
704 lb/ft
Full Force 160/100%
Stock airbox
Stock turbocharger
Stock transmission
Stock
Stock
Aftermarket tuning.
7/12 - 402 RWHP
Stock airbox
Stock turbocharger
Stock transmission
Stock
Stock
Aftermarket tuning.
7/12 - 402 RWHP
I've always thought that 160/100 injectors are about as large as one could realistically go without also needing to change other pieces of hardware on the engine. I would love to know if my suspicion is close to being correct or way off base.
I am totally surprised to see that you are producing over 400 rwhp on a totally stock transmission. Is it a manual or automatic? Are you having any issues or does the trans seem to be holding up well enough?
Following this tread. Always nice to see how everybudy is doing. I myself was thinking about doing 200/80 injectors but do like how the 160/100's sound. I really have to tow and don't want to have to do the hole motor if not necessary. I liked Robins numbers but didn't know how much he really towed.
328 hp
704 lb/ft
328 hp
704 lb/ft
No worries if "No Limit" does the dyno @RRE, they take full controll of your truck, all you get to do is stand on the sidelines and watch...
Really?! That may be nerve-racking as hell! But, I guess they know what they're doing. Is that who is doing the dyno this year?
Will the stock parts hate life with 238/200% injectors? Undoubtedly so. How long will the parts last? Who knows? I drive like an old lady most of the time though......
Have no fear though, it's getting a NAPA rebuild kit within the next few weeks to get rid of the 256K mile factory frictions and steels. I might spring for a good torque converter though if it turns out that the current one is the culprit for the slipping (I can't tell if it slips in 2nd because it just goes through that gear so fast...).
