What is this?
This is the reply I got when I asked the same question with a similar photo. LOL!
This subject has produced two of FTE's all time funniest threads:
https://www.ford-trucks.com/forums/5...-attached.html
https://www.ford-trucks.com/forums/8...k-is-that.html
I gotta ask, what could it possibly be in the way of?
Mark
Mark
https://www.ford-trucks.com/forums/1...l#post12733596
From some of the other threads Scott linked to in his post. Let the fun begin...again:
Can you tell we answer this question all the time?
Stewart
https://www.ford-trucks.com/forums/4...his-thing.html
https://www.ford-trucks.com/forums/5...the-frame.html
https://www.ford-trucks.com/forums/9...excursion.html
https://www.ford-trucks.com/forums/1...king-down.html
https://www.ford-trucks.com/forums/1...-removing.html
Look at it carefully. It increases the drag coefficient of the truck. That makes it use more fuel. Big oil doesn't want you to cut back on fuel usage so they bribed Ford to put it in. Also, when the CIA or FBI wants to track you, they will remove it and install one of their own that looks like yours but has a transmitter to pinpoint your position, record your conversations and figure out your underwear size if you wear underwear or if you are cleanly shaven "down there".
Stewart
