uk f3 ambulance
Old 11-27-2015, 04:37 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
Originally Posted by Bikelikealocal
hallo Stu.Youre right it is my truck now, in a fine condition, i feel so lucky, Hans
It does look to be in great shape. Congratulations. When you are able may we include its serial number, M-H numbers, and axle number in our records? Thanks.
Edit - also, I'm unable to save the pictures from the sales listing. May we ask you to post pictures of the truck? Thanks. Stu
  #32
Old 11-27-2015, 06:58 PM
thundersnow70's Avatar
thundersnow70
thundersnow70 is offline
Whats the story with the body shell Stu? The rear half of these don't look like a factory ford panel truck. Do you know if they cut the back of a pickup cab off and sent it to a coach builder or is this what ford panels looked like across the pond?
  #33
Old 11-27-2015, 07:09 PM
truckdog62563
Built in South Africa iirc, and specially coach built I'd guess. Never seen any others that resemble them. All are '51s, and I believe six cylinders. The other owners who have joined here haven't stayed real actively involved to help us learn about them. Hope Hans can offer some insights, history of their service, etc. Stu.
  #34
Old 11-29-2015, 08:10 AM
Bikelikealocal's Avatar
Bikelikealocal
Bikelikealocal is offline
i heard that there are 20 off this moel made for the army in Belgian Congo but they newer went down there, so the Civil defense used it as Ambulances in Denmark they had 19 cars
A750-A769 mine are No 754 i hope you can use it
  #35
Old 11-29-2015, 09:26 AM
truckdog62563
Interesting history. I just found this Hub Garage file of the dark blue ambulance in the UK. Stu
HubGarage.com - Rusty Davidson's Garage
  #36
Old 12-17-2015, 09:27 AM
Bikelikealocal
hallo Stu
i need a new Water pump and gasket for my 1951 F3 still don't know what size the 6 cylinder flathead motor is, is there different water pumps from 226 / 254 cubic
and is it possible to get some new tires, i need 5 tires 7.50 x 17 where do i order them
and last, brake line mine is steel and rusted, would like some in cobber so they last longer
Thanks a lot Hans j Grundtvig
  #37
Old 12-17-2015, 10:18 AM
truckdog62563
Hans - your engine will be the 226 cubic inch version. Both the 226 and 254 used the same water pump, 7HA 8501. The gasket is listed as included with the pump. If you have no local sources and must import from the US, my view would be that this is a perfect time to establish yourself and your M-H as customers of Chuck's Trucks in Connecticut. Chuck Mantiglia is the owner and is expert in these trucks. He is my primary parts source for my trucks. Below is his web page.
Chucks Trucks LLC., Chuck's Trucks, Chucks Trucks
Tires in the 7.50 x 17" size, having the aggressive traction tread, are today limited to the Tornel brand linked below. These are available on eBay, and from Coker.
https://www.cokertire.com/750-17-tor...on-10-ply.html
Brake lines to my view should be steel. I redid mine myself after buying a quality double flaring tool. Others can speak up if they have other viewpoints. Stu
  #38
Old 12-17-2015, 11:02 AM
Bikelikealocal
would the Tornel traction tire make more noise than Sta transport tires / Highway
im not going off road in the car, and Thanks again Hans J Grundtvig DK
  #39
Old 12-17-2015, 11:10 AM
truckdog62563
Yes, any traction tire will make more road noise than a highway tread. The STA available from Coker looks like your better option. Stu
  #40
Old 12-17-2015, 11:24 AM
Bikelikealocal
Great thanks Hans J
Spirit of '76
Large Truck
40
01-16-2017 06:03 AM
harleymsn
08-23-2015 10:16 PM
19fifty4
13
03-10-2012 12:50 PM
tinman52
04-06-2011 02:31 PM
va51f1
10-14-2009 09:02 AM
Quick Reply: uk f3 ambulance
