Bronco II Ford Bronco II
replacing timing gears
Old 02-05-2013, 02:38 PM
jake matthews's Avatar
jake matthews
jake matthews is offline
i found a 1985 bronco II that needs new timing gears and i want to fix it then sell it.
i would like to know how hard of a job it is on the 2.9l or if it is even worth it
Old 02-05-2013, 09:12 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
The 2.9 does not have timing gears, it has a conventional sprockets and chain.
The 2.8 (what a 85 will have) has timing gears, and are relatively simple to replace if you have the tools and good mechanical abilities.
Old 02-05-2013, 09:18 PM
jake matthews
thanks I meant to type 2.8.
Old 02-06-2013, 10:42 AM
f5fordgirl's Avatar
f5fordgirl
f5fordgirl is offline
Yes, the 2.8 has gears, the orig. ones had a steel crank gear and a fiber cam gear, the new ones will be steel crank, and alum cam gear. They have to be installed as a set, the teeth angle is off a little and won't match well with the orig. To change the crank gear you need to drop the oil pan for enough clearance to remove the gear.
erik68
02-08-2015 06:47 PM
Jonathan Page
03-26-2014 12:37 PM
ddmoyers
06-28-2006 02:03 PM
JRProaudio
12-16-2003 07:42 PM
geterdone
08-29-2003 09:40 AM
Quick Reply: replacing timing gears
