Pitman arm question
Old 02-02-2013, 04:38 PM
1oldtimer's Avatar
1oldtimer
1oldtimer is offline
Question Pitman arm question
Looking for a pitman arm for a 1957 F100, I'm not sure if that's the only year or is it '57-'60?. I'm looking for a pitman arm that goes on a 53-56 box but has the hole for a tie rod end instead of the ball...... anyone know if '57 is it or do they run later.
Also does anyone have one?.
Thanks
Old 02-05-2013, 06:59 AM
dewlister's Avatar
dewlister
dewlister is offline
My 58 has the tapered tie rod end hole.
Old 02-05-2013, 07:51 AM
FJones8668's Avatar
FJones8668
FJones8668 is offline
I believe I have just what you are looking for. My only question is if your steering box is the same diameter output shaft as mine. I know there were at least two different sizes (i have two) let me know and i'll go measure mine.
edit: I have been thinking and I remember the steering gearbox i switched out was a different size but i don't think the output shaft was different. In any event if you are interested in my old pitman measure your output shaft and let me know
Old 02-06-2013, 12:14 AM
1oldtimer's Avatar
1oldtimer
The boxes I have ('53-'55 and a '56) both have a 1 1/4" (1.250) dia pitman shaft. If that's what you have please pm me.
Thanks.
Old 02-07-2013, 11:28 AM
FJones8668's Avatar
FJones8668
I will measure today and have an answer for you this afternoon!
Old 02-10-2013, 08:45 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1953/56 F100/250 Pitman Arm is the same, but it's not the same as 1957 F100/250 and etc.
B8C-3590-A (replaced B7C-3590-A) .. Pitman Arm / Obsolete ~ 1 available NOS ~ I sent you an email with the source.
1957/58 & 1960 F100/250 2WD / Some 1959 F100/250 2WD (two different steering gears used in 1959) / 1961/62 F100/250 4WD / 1963 F100/250 4WD before serial number 380,001.
Old 02-10-2013, 04:09 PM
1oldtimer's Avatar
1oldtimer
Thanks Bill.
I've read that if I want a pitman arm that you can use a tie rod end on instead of the stock ball for a '53-'56 F100 box that it's '57 only. I've also read that '57-'60 might be the same, it sounds like maybe there's a difference in pitman shaft size from '58-'60 .
Old 02-11-2013, 04:02 AM
NumberDummy
Thanks Bill.
There's no such thing as a 1957 only F100/250 Pitman Arm.
1957/58 F100/250 and 1959/60 F100/250 2WD with Gemmer steering gearbox is the same.
1959 F100/250 2WD: There were two different steering gearboxes, Gemmer & Saginaw. Saginaw used a different Pitman Arm.
Old 02-11-2013, 09:57 AM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
So just cut 2 apart and make the one you need. If you don't have the confidence to weld it yourself, take it to a good welding shop. I've built several of them over the years. If you are going to do any sanctioned racing, you may have to have it x-rayed.
Old 02-11-2013, 12:16 PM
thrifty's Avatar
thrifty
thrifty is offline
Here is an another option. Take it to a machine shop, get a price on how much to drill out the ball and machine the tapered hole. Or see how much someone wants for one, then see how much shipping is. Just a couple of options.
Jonesy
Old 02-12-2013, 02:26 PM
1oldtimer's Avatar
1oldtimer
Thanks to Bill I found an nos one. I have one with the ball and one with the hole for whichever route I go.
hiyuu
Offroad & 4x4
09-09-2018 04:57 PM
fabieber
01-15-2015 09:36 PM
derherr65
22
05-03-2007 12:36 AM
The_Ryan_Lilly
07-23-2005 06:27 AM
Quick Reply: Pitman arm question
