HELP! Pitman arm
Old Jul 21, 2005 | 12:46 PM
The_Ryan_Lilly's Avatar
The_Ryan_Lilly
Exclamation HELP! Pitman arm
I cannot find a new bushing that connects the pitman arm to the steering.(Track rod, or what ever it's called)
I have checked all the parts stores around St.louis, no one has a listing for the part. Where can I get this from.
Thanks for any Help.
Old Jul 22, 2005 | 07:00 AM
jowilker's Avatar
jowilker
Is it not a ball joint? Is your truck 2wd or 4wd?
John
Old Jul 22, 2005 | 07:58 AM
4Cammer72's Avatar
4Cammer72
its the tie rod end i thought. that should be at any parts store.
Old Jul 22, 2005 | 09:40 AM
oldhalftons's Avatar
oldhalftons
The only thing that that connects to the pitman arm and the steering is a drag link.
The inner and outer tie rod are both on the drivers side and connect to the drag link.
If its not that, and your looking for a pitman shaft bushing for a bendix steering box, it will need to have the case machined for a new bushing, but the rebuild kits have a redesigned bushing that uses a smaller contact area. they work but don't look that tough.
If its the lower pitman shaft bushing/seal in a ford steering box it should be available.
Old Jul 22, 2005 | 12:09 PM
4Cammer72's Avatar
4Cammer72
youre right old half, i got it backwards in my minds eye. the drag link is still available at the parts shops though so it shouldnt be hard to find it.
Old Jul 23, 2005 | 05:44 AM
The_Ryan_Lilly
The guy at the shop (state inspection time) said it was a center joint/bushing at the pit man arm. I havnt ever done much work on steering, But I just looker under the truck, and it looks like the tie rod end on the drag link is bad where it meets the pitman arm, I guess i wil replace the other tie rod ends at the same time.
Thanks for the help.
Old Jul 23, 2005 | 06:27 AM
jowilker's Avatar
jowilker
I guess ball joint may not be the correct term, but I am referring to the swively thingie, that you put grease into.
John
