Fuel delivery question
Old 01-28-2013, 12:20 AM
Thomsen's Avatar
Thomsen
Thomsen is offline
I am working on an 89 f-150 with a 5.0. It has been sitting for about 3 years without running. The truck was running when it was parked, it sat for awhile and it was discovered that mice had carried wheat through through the pvc hose and into the valve cover. So I pulled the drivers valve cover and cleaned everything up. I went to start the truck and I couldn't get it to fire. I checked to see if I had any fuel pressure, and there is no pressure. The in tank pump is running. I am getting fuel up to the in-line pump on the frame rail, but no fuel coming out of it. My question is this, does the in line pump run off of the same relay as the in tank pump? How does the in line pump kick on? Is there a different relay that runs the inline pump? I am just wondering if there is something else I should be checking before I go buy an in line pump. Thanks.
Old 01-28-2013, 09:10 AM
Conanski's Avatar
Conanski
Conanski is offline
Both pumps are on the same circuit so it sounds like the frame pump is dead.
rkeith213
06-23-2014 03:18 PM
Coverbrooke
04-13-2012 06:54 AM
90fordguy
10-02-2005 11:47 AM
V8 Andy
10-08-2004 07:23 PM
jwrboss302
12-21-2003 07:25 PM
Quick Reply: Fuel delivery question
