question on converting to an electric fuel pump
I'm reading over posts and looking over the tutorial (How to replace your mechanical fuel pump with a Facet Duralift electric fuel pump) but none of them seem to cover the source connection.
Do you connect to the supply line that was leading into the mechanical fuel pump or do you connect to the tank selector valve?
Pictures of how you did either would be great!
I've got everything else covered (relay, pump, etc.)!
Well I'm not an expert but what I did was just take some 5/16" rubber fuel hose, slip it over the end of the existing hard line right by the old pump, and route it up past the vacuum pump to a 5/16" barb screwed into the e-pump. Working great so far. A good mod to do, the truck starts with less cranking.
Spectra brand is the one I went with next, and that one was small enough to fit perfectly.
Texan1983
Offroad & 4x4
43
04-26-2008 02:51 PM
Hndyman
09-25-2006 06:14 PM
