Bronco II Ford Bronco II
2.9 bogs down over half throttle
Old 01-27-2013, 06:38 PM
sf76's Avatar
sf76
sf76 is offline
as long as you ease down on the throttle its ok, but push it down hard it bogs down, let up an gets power back. thought it was the fuel filter but changed it, no difference HELP its my work transpiration
Old 01-27-2013, 11:22 PM
fenix1's Avatar
fenix1
fenix1 is offline
Mine is having idling problems. Am sure it's either the Throttle Position Sensor on the intake or the Idle Air Control Valve. In your' case it definitely sounds like the TPS. That's what i'd check first.
Old 01-28-2013, 12:48 PM
sf76's Avatar
sf76
sf76 is offline
well, had to take it to the mechanic. he thinks fuel pressure problem. will update when i find out.
Old 02-03-2013, 11:41 AM
sf76's Avatar
sf76
sf76 is offline
got it, was a fuel pressure problem. 23 lbs of fuel pressure, not enough. replaced fuel pump an pressure reg. runs great, i live in oregon we have ethanol fuel.10 % it eating our old stuff up!!!! if you have any power problems , idle ,acceleration, power surges, first thing CHECK FUEL PRESSURE .I drive a tank truck an see first hand what this stuff is doing.its not good,cut open old pressure regulator not much left of it , hope this can help others out,with out going to the shop, cus its expensive, thanks for the help !!!
Old 05-05-2013, 06:49 PM
Eileen Pike's Avatar
Eileen Pike
Eileen Pike is offline
My Bronco II was having Similar issues. If You have a Stick, I would say that You May want to Look into the Clutch! I check into it with mine and sure enough that is all it took!
Old 05-07-2013, 12:34 AM
Eileen Pike
Bogging down when You Give it More Gas? If You Have a Stick Shift, Look into The Clutch!
We were having a Bog Down Issue With Our Bronco II, And the clutch seemed a bit off!
Replaced the Slave Cylinder and Pressure Plate, Now She Runs Perfect!
Old 05-07-2013, 12:36 AM
Eileen Pike
Smile
Check into the Electronic Brain that is under Your Distributor!
Old 07-04-2013, 08:50 PM
mdr617's Avatar
mdr617
mdr617 is offline
I had the same problem with my 88 2.8 5-speed, it was the Idle Air Control Valve which I replaced. I also removed and cleaned the throttle body.
Tyler.172
07-19-2016 04:22 PM
tbirdscott
08-22-2013 12:54 PM
1999SuperDutyStroke
15
07-10-2010 10:27 PM
yeldarb82
13
03-05-2009 07:14 PM
GammaDriver
05-15-2002 11:00 PM
Quick Reply: 2.9 bogs down over half throttle
