fuel pressure
Old Mar 5, 2009 | 01:57 PM
yeldarb82's Avatar
yeldarb82
fuel pressure
I have a 96 f350 I checked my fuel pressure and it was a 40psi when i hold the throttle down it drops to about 25psi. I tryed the bb in the fpr but still got the same fuel pressure readings.
Old Mar 5, 2009 | 02:33 PM
kawa's Avatar
kawa
What and how are you measuring the fuel pressure? Are you taking it from the schrader valve or port? It should be around 70# at idle and will raise under acceleration.
Rog
Old Mar 5, 2009 | 02:55 PM
yeldarb82's Avatar
yeldarb82
i am taking it at the schrader valve
Old Mar 5, 2009 | 03:00 PM
MADVAN's Avatar
MADVAN
Your pressure is abit low.
49state 50psi, Cali 70psi idle.
Could be time for a pump.
Check and clean your return screen.
A clean screen removes air from the system.
Bill
Old Mar 5, 2009 | 03:09 PM
yeldarb82's Avatar
yeldarb82
Is there a screen on the pump?
Old Mar 5, 2009 | 03:37 PM
turboftw's Avatar
turboftw
i believe it is under the FPR. someone correct me if im wrong
Old Mar 5, 2009 | 04:17 PM
KevinC.'s Avatar
KevinC.
It is between the FPR and fuel filter housing. Take out the two 10mm bolts holding on the FPR. No need to undo any hoses, and carefully pull the FPR away from the filter housing. The screen is inside a little port. Mine was completely clogged, cleaning it made a world of difference. But be careful not to drop any of the parts in the valley of death. I dropped screen in there twice, found it the first time and had to buy a new one the second time.
KevinC.'s Avatar
KevinC.
And there is no screen on the pump, and welcome to the site BTW
Old Mar 5, 2009 | 05:26 PM
yeldarb82's Avatar
yeldarb82
Thanx for all the help guys. I cleaned the screen it was plugged up. Made a Huge diffrance in power!!
Old Mar 5, 2009 | 05:47 PM
richdawg's Avatar
richdawg
Is that the same screen that is recommended to clean with a (Q-tip cotton removed) when changing the fuel filter?
Old Mar 5, 2009 | 06:16 PM
KevinC.'s Avatar
KevinC.
well that would be the screen but no need for cleaning it every filter change. I filled a cap with lacguer thinner and soaked the screen in that. Worked amazing.
Old Mar 5, 2009 | 06:39 PM
richdawg's Avatar
richdawg
I haven't changed my fuel filter yet, so just wanted to clarify the best way to clean the screen. I'll just try and determine how dirty it is and go from there, as to weather I take of the FPR. I am assuming that there are no gaskets to replace?
Old Mar 5, 2009 | 06:45 PM
kawa's Avatar
kawa
Yes, same screen. It only gets clogged on the filter side so there is no real need to remove the FPR.
Rog
Old Mar 5, 2009 | 07:14 PM
richdawg's Avatar
richdawg
Sorry about hi jacking this thread, but now it seams like the originator may have solved his problem backwards, and may need to change fuel filter.
