351 Windsor Not Starting
Old 01-26-2013, 07:33 PM
cgiles85's Avatar
cgiles85
cgiles85 is offline
Hello,
Im trying to buy a 1990 F-150 with a 351 Windsor, however the engine won't start and I don't want to buy the truck until I hear that engine run. Heres the details.
- Tank has gas
- Fuel pump is operational
- Fuel is getting to the rail
- All plugs are sparking
- Tried the position sensor in the transmission, no change
- Fuel pump relay was replaced, no change
- Belt is off (dont think this will keep it from starting though)
- Has new distributor cap, plug wires and plugs
- Engine is EFI
Seller says the engine was running fine, then it started acting up for a while, the truck was put in storage, now it doesnt start at all.
Engine just turns and turns but will not catch. Someone said it could be the EEC relay, has anyone else had this problem? Any solutions?
Thanks
Old 01-26-2013, 09:53 PM
Redtires019's Avatar
Redtires019
Redtires019 is offline
Do you have access to a set of 'Noid lights" to plug inti the injector plugs and see if the computer is pulsing the injectors?
Old 01-26-2013, 10:33 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Can also ask the computer what it thinks is going on:
Fuel Injection Technical Library » How To Run a Self-Test
Old 01-27-2013, 07:41 AM
cgiles85's Avatar
cgiles85
cgiles85 is offline
No I do not have Noid Lights. Can I buy these easily? I have never heard of them.
cgiles85's Avatar
cgiles85
cgiles85 is offline
I will certainly do this procedure. Thanks for the link.
Old 01-27-2013, 11:10 AM
Redtires019
Noid lights are test lights that plug into the harness in place of the fuel injector plug to see if the computer is firing the injector.
I would check everything else first, but I had a pickup a few years ago that the computer was not firing the injectors. I wound up replacing the computer. I believe (if I remember right) the injectors are hooked to a key on power and the computer controls them by grounding them to turn them on.
cgiles85
01-31-2013 10:56 PM
Bowtie95
09-02-2012 01:25 AM
kamen1
03-02-2012 07:44 AM
redwolfhopw
18
05-20-2008 08:32 PM
Quick Reply: 351 Windsor Not Starting
