1990 F350 problem
Old Mar 1, 2012 | 09:21 PM
kamen1's Avatar
kamen1
1990 F350 problem
Hello
New to the furum. So thanks in advance. Well I have a 1990 F350 with 7.5L that starts and then dies out. First thought it was was a tune up. I then replaced spark plugs with wire and distributor cap plus rotor. No luck. Next I took a friends advice and replaced TPS with same result. Stumped my buddy said he had a similar problem in his 89 which was the injectors, so I replaced those. I then had my buddy start it and before it could die I kept it running with some starting fluid. I grabbed a fuel pressure gauge and checked pressure @ 40psi while key was in the run position. But the pressure didnt hold. It seemed like after a second or to the fuel pump would shut off. This was the same for both tanks. I replaced both fuel pumps 5000 miles ago and think there still good. So today I change fuel pump relay, and EEC relay, fuel pressure regulator and still no where. Any sugfestion?
kamen1
Old Mar 2, 2012 | 07:44 AM
subford's Avatar
subford
If they run for one second and quit then you know the fuel pumps, fuel pump relay, EEC relay are all OK.
Sounds like you have been getting some bad advice and it is costing you a lot of money. You should have come here first.
When the key is first turned on the computer will start a timer in the computer that runs for one second. This timer will ground the fuel pump relay.
Then the computer will wait for a PIP pulse from the distributor, when it sees a PIP pulse it will reset the fuel relay timer and the pumps will run for one more second. This PIP pulse will come faster than one second while the engine is cranking or running so the timer never times out as it keeps getting reset.
All of that said you either have a bad wire from the PIP sensor to the computer or a bad computer. Could also be the computer plug.
skylonda
Jul 20, 2020 07:36 AM
88150guy
Nov 8, 2017 11:34 AM
gearhead351
Apr 23, 2010 07:19 AM
rgd420
Feb 2, 2005 08:55 AM
buddystrore
13
Jun 23, 2004 11:14 PM
