Changing trans fluid
97 f250 auto trans. Can I just drop pan, put new filter in and refill ?
Or is there more I should do, like drain convertor. I did have a flush done a couple of years ago but not filter change. Got a little hard shifting going on at high rpms, so I thought I'd at least change fluid and filter for starters
Mike
Mike
Cant give you info on your shifting...
Drop the pan, change the filter. There should be a drain plug on the torque converter too. Most of your fluid will be in your converter. Some guys say dont remove the plug. That is why they made flushing units. However, when I took my truck to Ford to get a trans service, they removed the plug and said "Thats how you do it".
Did not get the last post until I was already done.
This is what I came up with
I am using motorcraft mercon v
Drained 12+ qrts
Replaced 12 - started engine let idle for 15min then drove around a bit
Checked idle in park - nothing on stick
Add another qrt - drove around then checked - nothing on stick
Yikes - up to 14qrts now - was I running it that low? Did I drain or spill more then I thought? Gotta go get more fluid. Bought 8 to start with and went and got 6 more. Probably go get 4 more
BTW - bought first 8 at my local ford store for (I think) $8+ a qrt. And then last night I found it for less then $6 at orieleys (Gresham or)
Drained 12+ qrts
bchitwood73
1997 - 2003 F150
08-15-2012 08:41 PM
vze2sgxa
1997-2006 Expedition & Navigator
05-29-2009 02:15 PM
