Modified gas tank???
Old 01-24-2013, 02:38 AM
mtdorf's Avatar
mtdorf
mtdorf is offline
Ok, I want to get rid of the behind the seat fuel tank in my 59 f100 as i'm tired of smelling the gas and I want to have that little extra room for my long legs and bigger belly. I want your advice/opinions and expertise on how to go about mounting another fuel tank. I have a couple of side tanks from various year f150s and 250s. I also have a friend who said he can fabricate one to fit within the frame just under the bed and would hold upwards of 50 gallons of fuel.
So anyone who has done this please chime in as I need the advice and knowledge.
Thanks
Old 01-24-2013, 04:55 AM
Walston's Avatar
Walston
Walston is offline
There are pictures in my gallery. I used a 1969 mustang tank. My fill tube is located behind the license plate.
Old 01-24-2013, 10:36 AM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
I put a Rodeo 22 gal tank behind the rear axle between the frame rails, with the filler through the rear quarter panel.
50 gallons of fuel takes a considerable amount of space.
Good luck in your quest!
Old 01-24-2013, 02:25 PM
ibuzzard's Avatar
ibuzzard
ibuzzard is offline
Panties NOT in a Twist
I believe that simply removing the tank, in and of itself, will not give much if any additional room to adjust a stock seat backwards. You would, I believe, have to either change seats, or relocate the mounting holes or rails. Even then, the stock seat would need to be adjusted to almost straight up, or perpendicular to gain much. The greatest gain would come from using a different steering column to move the wheel closer to the dash.
You could always remove a six inch section of your femurs, and notch the steering wheel to accommodate your belly, might be cheaper.LOL!
Old 01-24-2013, 03:26 PM
mtdorf's Avatar
mtdorf
mtdorf is offline
i have been trying to figure out a way to remove the six inches of extra gut...seems that most conventional fabrications require some sort of medical background LMAO!!
Thanks to all who replied, if I'm successful I will post pics.
Old 01-24-2013, 05:36 PM
spurredon's Avatar
spurredon
spurredon is offline
Here's some reading for you along this line of thought before you cut yor legs off! INSTALLING A MID-60's Mustang Tank in a '53 F-100 truck
Old 01-24-2013, 07:07 PM
ibuzzard's Avatar
ibuzzard
ibuzzard is offline
Mtdorf, I am 5'9". Our era trucks are admittedly short on legroom. With my seat all the way back, which I need to do also, the top of the backrest is touching the rear of the cab, so it cannot go back any further, no matter if the tank is there or not. Perhaps if I moved the stops in, I could gain an inch and a half, but my seat would be uncomfortably upright. Perhaps different seat may gain you something, but I do not know.
By the way, my stomach has never been described s minuscule, either.
Steve
Old 01-24-2013, 08:52 PM
economan's Avatar
economan
economan is offline
switch over to a 57-60 panel bodied truck then you will have upwards of 6 feet to move the seat back (heh heh)
mikie
near ottawa canada
58 m-100 panel, 64 econo p/u
Old 01-25-2013, 08:16 PM
mtdorf's Avatar
mtdorf
mtdorf is offline
My wife says i just need to fabricate an extra cab, that way i'll fit and all my toys can go with me on my trips...she is tired of holding the rifles when we travel!!
flyinbrian04
13
02-27-2016 05:04 PM
ireding
08-21-2014 10:34 PM
rcav8or
38
06-04-2008 10:34 PM
72/88/binder
01-19-2004 07:39 PM
onewaymike
02-06-2002 07:11 PM
Quick Reply: Modified gas tank???
