1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Lub dub hiss
Old 01-18-2013, 11:12 PM
blackestate's Avatar
blackestate
blackestate is offline
Lub dub hiss
Ok, after changing the plugs etc. it still has a miss, and rough idle.
When I was under the hood listening, I noticed that sometimes when it misses there was a hiss sound. I opened it up at the air cleaner, and I am hearing like a heartbeat when it misses, lub dub, then a hiss.
Is this a valve? bus since it is occasional, is it a lifter? I assume this has hydraulic lifters. And if it is a lifter, can I clean it with a little seafoam in the oil?
Could this be a cam/crank sensor starting to fail?
pulling the connections to the coils, and the injectors all provide a constant miss. this is driving me nuts,
Thanks for any input you can give.
Doug
timbersteel
20
07-18-2012 02:09 PM
slafronza
1997 - 2003 F150
03-13-2010 09:36 PM
jwgeorge
16
08-24-2005 10:08 PM
SlickRanger
4 Cylinder Engines
11-03-2004 09:36 AM
mrwizard
03-15-2003 07:43 PM
Quick Reply: Lub dub hiss
