blower motor resistor/ cruise control
Blower only works on high, fuse is good. I read the resistor is supposed to be under the glove box, but I can't find it. 85 with a/c.
Cruise control doesnt work, I got as far as checking the fuses, brake lights and vacuum hoses, any resources on troubleshooting? 5.0 FI.
The blower resistor is under the hood. It looks like a wiring plug plugged into the ductwork. They mount the resistor there so the airflow from the blower keeps the resistors cool, they get red hot and like to set leaves on fire if they get into the duct.
If your resistors are good, I have found on some of the later models(I don't know if the earlier models had this) there is a thermal fuse in the resistor network. It looks like a small silver barrel. It's the same type they put in coffee makers, but I don't know the rating that Ford used. If you have one, check it for continuity. If it's open, that's probably your problem. I have wired around them and put them back in, but you can do this at your own risk.
The cruise control can have several problems. Do you have vacuum to the system under the hood? Is your brake switch going to the system ok? There is also a vacuum switch on the brake pedal. And another problem area is behind the steering wheel. There is a set of contacts back there for the switches. Does your horn work? It uses some of the same contacts, and I believe also the cruise buttons get there supply voltage from the horn circuit(fuse).
The front side (where the wires connect) looks like this:
See if these threads help you:
https://www.ford-trucks.com/forums/9...s-on-high.html
https://www.ford-trucks.com/forums/1...stor-fire.html
https://www.ford-trucks.com/forums/8...g-trouble.html
If you figure out what the temp rating of the original is, write back in and let us know. It would be sort of like putting in the wrong fuse in the fuse box if you just "put one in" without knowing the rating. It could be too low and give you trouble opening up prematurely, or be too high and be the same as me putting a jumper in and not do any good.
ECONOLINITIS
12-21-2004 11:08 AM
jrs_big_ford_f150
10-14-2002 12:47 PM
