Mirror connector schematic
Am in the process of upgrading my 2000 F250 to 2012 mirrors (told they was that year model?). Before I start the wiring process this weekend I was just trying to get a grasp of where each wire was going to go. Does anyone have a schematic for this plug show what each wire is for?
The plug/connector:
Hoping to find an image like this of the connector:
The plug/connector:
I believe the connectors are ford proprietary and can only be obtained from them? I just used the connector to identify each wire and then just discarded it. I went the cut and soldered route with installation.
Not sure exactly what you're asking but I'm assuming you're installing mirrors w/o the power fold and extend option? If that's the case then you'd just have to cut the connectors off your 2000, match them up to the new mirrors (adjustments), and then run additional wiring so you can use the defrost, running light, turn signal options. The defrost you'll just need to find a power source and the lights/signal just tap into existing truck wiring of the power.
Kwikkordead
33
04-21-2010 06:49 AM
