F250 shutting off while driving
I have a 1994 F250 gasoline engine. It will cut off while driving down the road, sometimes it start in a few minutes and sometimes it takes at least a day. Each time it happened I check the firing. During the times it won’t start there is no fire at the coil or the distributer. I have changed the coil. Any suggestions Thanks Donnie
I had a '78 Bronco that did the same thing. My brother in law was a Ford mech and he came over and opened up the wire harness under the dash. He felt the wires separately and he told me which one to replace. One was hot and he said it was broke inside. When it got hot it would separate and the engine would die and after a minute or so the wire would cool down and it would start again. It never did it again!
Your problem sounds similar to an issue I was dealing with. Some of the guys on this forum suggested coil,distributor pickup, ignition control module as potential problems. In my case I replaced the distributor and coil and it cured the problem. It was the distributor that was causing the stalling and no start conditions
texans
26
09-02-2011 05:31 PM
KPMariner05
1999 to 2016 Super Duty
15
07-25-2007 05:38 PM
skattnig
06-12-2007 01:40 PM
