4R100 high rpm
I don't see anything here that points to ANY problem with the transmission, and that includes the torque converter.
I do think you should change the transmission fluid. Changing only what's in the pan changes about 7 of the 18 quarts this transmission holds. I don't understand your hangup about the pan, why do you need to remove it? Did you read the link I posted that shows how to change ALL of the trans fluid without removing the pan?
As others have pointed out you may have a failing catalytic converter. That can hurt engine power and make various noises.
Binkdaddy
10-22-2003 03:00 AM
