Any info on ZF5 swaps?
FTE Thread: Gary Lewis' ZF5 to a 351M/400 (4WD)
I have put one in my '66, and am in the process of doing the same on my '73. It isn't too hard, but takes a little custom fabrication. For the dentside trucks, The firewall must be reinforced or the sheet metal firewall will fatigue and tear. I am planning a fairly large reinforced plate to distribute the load across the firewall. I haven't quite got the geometry down yet, but have a plan, and will post pics when I am done. As far as the part numbers, use look up any 90's truck with a manual transmission. I believe they are all the same. What motor/trans combo are you going with?
On a 77 crew I had I did mechanical linkage, it was easier than the hydraulic (for me) used stock pedals, frame and block pivots and the rod to the fork, drilled a hole in the fork (actually ground a hole, fork is hardened) the only tricky part was the Z bar, getting the ratios right, when I was done it was easy to push and had enough travel.
The only thing that would be better with hyd is the when the engine moves under load you can feel it in the mech linkage, but I know the mech linkage will never fail a master or slave cyl.
groundup420
16
02-19-2018 11:59 PM
m37
01-09-2014 01:25 PM
