F 250 Super Duty Lift removal
Me and my father, who is a certified ASE technician, have never removed a lift. We have however, installed one on my 1999 F250. I dont know how big of a lift is on your truck, but my lift is a 6in skyjacker lift. All we had to drastically change was the steering linkage and traction arm. Obviously, you are gonna need new leafs, shocks, and probably ubolts and rear blocks as well. Other than that, everything should fall back into place. You will need also need to use your old steering pitman arm (once again, depending on the size of the lift). I never had to mess with my brake lines at all because the stock length was enough for 6 more inches.
Other than that, i cannot think of much else, hope this helps!
If you have any questions, i practically have a scrapbook of pictures of every step we did to get it right. Let me know if you wanna see any.
Return track bar to original geometry (usually has a longer/adjustable bar, or drop bracket), return pitman arm to original design, new shorter shocks, original leaf springs, shorter rear blocks most likely (f250=2", f350=4", but it doesnt matter which you pick). new u bolts all around. shorter sway bar links in the front, tires that fit... about all i can think of now. my friend went from a 6" kit to just a leveled F350 by trading suspensions with someone. they did it over a weekend
The only lift I have is a leveling kit and a 5" block in the back.
Stock for the F350 is 4" and I removed the 5" because they got me
the wrong blocks. I need the non-tapered ones and they sold me a set
of tapered blocks. Talk about vibrations. Pinion was so far off that
I could not pull out with out a good bit of vibration. So here I sit with a
set of 5" tapered blocks in a box on a shelf. They said I could ship them back
for a credit or replacement. Not sure what to do with them. Just more $ out the
door even if they exchange the set I still have shipping costs.
Sean
Sean
Sean
Sean
The stock in my 06 are the non-tapered. It has to do with the pinion angle
Have a look here.
Measuring the Pinion Angle - HotRodHigh.ca
Sean
NOTE : How To Set Pinion Angle http://www.carcraft.com/howto/91758/
Have a look here.
Sean
TERSEJR
11-16-2003 11:27 PM
TrueBlueV10
1999 to 2016 Super Duty
08-05-2003 07:39 AM
