Lift recommendations..
Old Sep 29, 2005 | 02:34 PM
76 Chunk's Avatar
76 Chunk
I would like to lift my 76 F100 4x4 enough to fix 35's. What is the best way to lift this truck without killing my wallet. I am not partial to any brands. I am new to the 4x4 world so any help/suggestions would be appreciated! Thanks!
Old Sep 29, 2005 | 03:56 PM
MBBFord's Avatar
MBBFord
A 4" lift will clear 35s with no rubbing on even the roughest terrains.
I'd say look at jeffsbroncograveyard.com for some ideas.
If you put 7 degree c bushings you might be able to get away without needing radius arm drop brackets(look at the 14 peice c bushing set, gives you what you need to replace warn out parts for $48).
Get some 4" lift coils($120 or so) for the front along with a 4" Drop pitman arm($50 or so) and some extended brake lines($35 or so). For the back put 3" blocks(about $25-40) or a 3" add a leaf or do a shackle flip(3" $15 for 4 grade 8 bolts).
You might need a drop track bar bracket also($32) or get a adjustable track bar($120).
I'm getting a 6" lift and I need all the same things just a little bigger plus drop down radius arm brackets and b/c I have sway bars and for some reason I'm keeping them I'm getting a drop link for them too.
Old Sep 29, 2005 | 11:13 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
for cheap...i would just drop the coils buckets two inche sin the front, get longer shocks.... then or the rear, get longer shocks do a shackle flip like i did in my gallery for 2 inche sof lift. 2 inches is all you need to fit 35 with NO rubbing
Old Sep 30, 2005 | 04:51 AM
tacmed33's Avatar
tacmed33
KO-76 eplain this 2" lift one more time... I have a 77 F150 that I would like to stick 35" under without needing all the changes of a 4" lift. thanks
Old Sep 30, 2005 | 07:51 AM
76 Chunk's Avatar
76 Chunk
Thanks for the detailed info! I'll get to looking!!
Thanks also. This might be the cheaper way out! But not as much lift..
Old Sep 30, 2005 | 09:09 AM
MBBFord's Avatar
MBBFord
No problem, the numbers are all still fresh in my head so it was easy to list them for a better look for you.
