kickdown rod
Old 12-23-2012, 04:56 PM
White Boy's Avatar
White Boy
White Boy is offline
kickdown rod
does anyone have a picture of how the kickdown rod connects to the carb
Old 12-23-2012, 05:41 PM
tbear853's Avatar
tbear853
tbear853 is online now
Received 1,288 Likes on 1,089 Posts
'77 F150 351m with C-6 and Edelbrock carb... the extension needed because 4bbl intake moves primary bores forward of where they were with stock 2bbl intake.
Old 12-23-2012, 05:50 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by White Boy
does anyone have a picture of how the kickdown rod connects to the carb?
The year/series/engine size/transmission type is?
Please, when asking questions, list all the pertinent info. Parts catalog pic will show the whole shebang, once the info is known.
Old 12-23-2012, 05:56 PM
The Masked Rider's Avatar
The Masked Rider
The Masked Rider is offline
I think the rod lengths - 2v vs. 4v, are different. Thus the reason Bill (ND) asks for you to post vital info...
Old 12-23-2012, 05:59 PM
White Boy's Avatar
White Boy
1978 ford f150 c6 tranny. 6.6 400 v8 motor 4 barrel carb
Old 12-24-2012, 05:54 AM
NumberDummy
No 400 came from FoMoCo w/a 4V carb, 2V only, so the parts catalog pic reference I was going to give you, will not be correct.
Old 12-24-2012, 06:00 AM
White Boy's Avatar
White Boy
Ok so now it has a 400 and a 4 barrell carb. Is all i need it the small extension bracket
Old 12-24-2012, 06:16 AM
The Masked Rider
Is the rod hollow. Maybe you could cut it, thread each end and use a short piece of threaded bar. Or maybe braze in a piece.
Old 12-24-2012, 06:20 AM
NumberDummy
Is the rod hollow (tis). Maybe you could cut it, thread each end and use a short piece of threaded bar. Or maybe braze in a piece.
Or use a Lokar cable instead.
Old 12-24-2012, 09:30 AM
gpence's Avatar
gpence
gpence is offline
Why not just go to the junk yard & grab a kick down rod off a 4V truck?
Old 12-24-2012, 11:41 AM
460me's Avatar
460me
460me is offline
Old 12-24-2012, 01:06 PM
wasowski's Avatar
wasowski
wasowski is offline
i have some of the same problem,i put a 390 in my 79 150 supercab,and because i had to change some stuff on the transmission like shifter linkage because of the n.s.s. is on the trans ,i,m not sure if i should use the kickdown that was on the 76 set up or use the kickdown from the 79 because i put a 79 style shifter in the 76 c-6,
i guess the real question is when does the kickdown engage?
the carb is the replacement holley 4160 which the old was ware out
and yes i spell and type like a 3 yearold sorry
Old 12-24-2012, 03:01 PM
gpence's Avatar
gpence
gpence is offline
I used the nss plug from a manual truck & the older kick down rod off a FE truck in my 77
Old 12-24-2012, 07:34 PM
The Masked Rider
Bill, I was going to mention Lokar but last time Lokar was mentioned for a throttle linkage, everyone complained about the cost. I use Lokar on both throttle and kickdown. I spray cable lube in them every yr or so. Have had them on one truck for about 15 yrs with no problems. I use a special cable lubing tool - same one used for motorcycle cables.
Old 12-25-2012, 12:24 AM
tbear853's Avatar
tbear853
Find the pin ... about 5/16 diameter with groove fopr retainer if you have the Ford kick down linkage on the carb .... have someone mash gas WO and hold, then push trans kick down rod back, and simply measure length needed to add to it. I made my extension in my pic from some 3/16" X 3/4" steel, I bolted it to the kick down rod using a 5/16" bolt and unt and used a 5/16" hole to slip it over the pin on the linkage and installed a E clip.
White Boy
12-25-2012 09:22 PM
White Boy
12-24-2012 11:30 AM
White Boy
02-13-2012 07:24 PM
Kazco
02-19-2009 02:08 PM
dave186
06-06-2000 08:20 PM
Quick Reply: kickdown rod
