Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 12-18-2012, 07:02 AM
Engalwood Engalwood is offline
Garage is empty, add now
Engalwood is starting off with a positive reputation.
99 F550 7.3
I have a ? on the abs light. Im in the process of changing out that Ball Joints . I figured while I was at it I would fix the ABS light that been on for some time. How do I figure out which sensor is bad? I know I dont want to replace them all bc they are between $170(Motorcraft)-$70(Cheap one).
I am just wondering if there is a way I can track this down and figure it out
  #2 (permalink)
Old 12-18-2012, 08:06 AM
snakedoc's Avatar
snakedoc snakedoc is offline
Ford With Out Tax Money
1999 Ford F-250
snakedoc has a great reputation on FTE.snakedoc has a great reputation on FTE.snakedoc has a great reputation on FTE.snakedoc has a great reputation on FTE.snakedoc has a great reputation on FTE.snakedoc has a great reputation on FTE.
not to be the bearer off bad news, but mine did this and it was my hubs going bad.
i have seen where you can jack up the tire and spine it will having a meter plugged in to the abs sensor/
__________________
Matt PAA #117 99.5 F-250 XLT CC SWB 4x4 AUTO Warn M12000 GPR-LED. Foil Delete. 6637. 0.25 Cent. AC. Isspro Dual Pyrometer. AeroForce. FRx. DIY SS Fuel Lines. 03 HeadLights. 4" SS Exhaust. 6.0L Trans Cooler. BTS Tunes. Member On RHN
2001 F-550 auto 73000 miles
  #3 (permalink)
Old 12-18-2012, 08:17 AM
schlepprock250's Avatar
schlepprock250 schlepprock250 is offline
Guns Dont Kill People..
1999 Ford F-250
schlepprock250 has a great reputation on FTE.schlepprock250 has a great reputation on FTE.schlepprock250 has a great reputation on FTE.schlepprock250 has a great reputation on FTE.
fordf250guy
But the good news is,you can get Timken brand hubs from Autozone for about $160...and I believe they come with new ABS sensors..
Edit..not sure if the f550s are the same though..
  #4 (permalink)
Old 12-18-2012, 08:44 AM
mueckster's Avatar
mueckster mueckster is offline
aka Redneck Wrencher
mueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant future
Roland Mueck
Here are some ohm and voltage tests you can run.
Front ABS Sensor Ohm reading across the Sensor End connection
4x2 F250/350: 2,000-4,000 ohms
4x2 F450/550: 650-800 ohms
4x4 F250/550: 650-800 ohms
Rear ABS Sensor (VSS) Ohm Readings
All: 800-3,500 ohms
A volt meter, set to the low scale AC volts, should show a fluctuating reading while the differential, or front hub, sensor ring is turned at a quick rate.
__________________
__________________
Roland-
'01 F-250 Lariat CC SB 4x4, DP Tuner F6 (live tuned), AFE II w/ Pete's Cover, GTP38R w/ Riffraff billet whl & 1.15, 6.0 Techni-cooler IC, Full Force SS Injectors, Stealth HPOP, Fluidampr, Melling M-208, Walbro FP, mueckster Reg Return & Bowl delete, 910 Springs, mueckster 4R100, 4" SS MBRP, 6.0 Trans Cooler, billet 710 cap, Truetrac rear
PAA Member #62
... From Rock to Rocket-- Thanks to the Brotherhood.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
